ASRock Fatal1ty Z170 Professional Gaming i7 Built for Serious Gamers
TAIPEI, Taiwan, November 3, 2015 – The ASRock-Fatal1ty Z170 Professional Series Gaming i7 is currently the highest performance gaming motherboard available. Built for serious gamers with Intel’s Z170 chipset. Our motherboard is designed with 12 power phases and supports the 6th generation Intel Core processors and the latest DDR4 memory modules. This powerful combination allows the ASRock-Fatal1ty Z170 Professional Series Gaming i7 to dominate your competition while playing the most complex PC games. In addition to the three native graphic output options, DVI-D, HDMI and DisplayPort, power users can further maximize graphics performance via the motherboard’s four PCI Express 3.0 x16 slots that fully support 3-way CrossFireX or Quad SLI.
Superior onboard LAN and audio is essential for high performance gaming motherboards, that’s why ASRock Fatal1ty Z170 Professional Gaming i7 is equipped with Dual gigabit Intel LAN chips, plus ASRock’s new proprietary audio solution Purity Sound 3. As for the data transfer and storage side, this professional series gaming motherboard holds ten SATA3 connectors, three SATA Express connectors. For maximum performance we’ve also included three more Ultra M.2 slots that allows M.2 SSD or Intel 750 U.2 SSDs to be built into a monstrous PCIe SSD RAID 0 array. For unmatched connectivity flexibility you’ll find eight USB 2.0 ports including the customizable Fatal1ty mouse port, also eight USB 3.0 ports, and two USB 3.1 Type-A and Type-C ports!
By Harry
