Microsoft has released Build 10586 of Windows 10 to “Windows Insider” previewers, as the first major update to the operating system nears release.
This build bears all the signs of a RTM (Release to Manufacturing) release, if the Insider rollout is successful.
The build number does not show on the desktop, and in Windows Update it is called “th2_release Professional”. The abbreviation is short for Threshold 2, this being the codename for Windows 10.
windows 10
You can think of Threshold 2 as being a fixed version of the initial release. A future release codenamed Redstone is rumoured to be coming late in 2016, with more far-reaching changes, though thanks to Microsoft’s adoption of the “Windows as a service” model it may still be called Windows 10.
Below is a list of fixes :
  • The issue where any audio playing (like music from Groove, or videos from the Movies & TV app) gets reduced by 75% for a period of time after a notification pops up from Action Center is fixed.
  • Pressing the power button on your Surface Pro 3 should put your Surface Pro 3 to sleep instead of shutting it down.
  • We fixed an issue reported by Windows Insiders where a disksnapshot.exe command prompt window would flash randomly.
  • Windows should now remember your previous login type. For example, if you log in with a PIN – it will prompt you for a PIN next time instead of another type.
  • We fixed an issue where Tab previews in Microsoft Edge were appearing as black if the page was not scrolled to the top, and web note clippings were also appearing as black.
  • Small form-factor devices, like the Dell Venue 8 Pro, that boot with rotation or virtual mode screen size set larger than the physical screen size should no longer experience a bluescreen on upgrade.
  • Apps and games should download from the Store more reliably.
Known issues:
  • After upgrading from one Windows 10 Insider Preview build to another Insider Preview build, Skype messages and contacts will disappear from the Messaging + Skype app. You can get Skype messages and contacts back by navigating to “C:\Users\<USERNAME>\AppData\Local\Packages\Microsoft.Messaging_
    8wekyb3d8bbwe\LocalCache” in File Explorer and deleting or renaming the “PrivateTransportId” file. After deleting or renaming that file, go to the Skype video app and sign out of Skype and sign back in.
  • The Insider Hub might be gone after upgrading to this build. You can get Insider Hub back by going to Settings > System > Apps & features and clicking “Manage optional features”, choosing “Add a feature” and selecting Insider Hub.
By Harry
