If you are looking for a HDMI 2.0 cable, you wouldn’t go wrong with the AmazonBasic’s 6 feet HDMI 2.0 cable. This HDMI A Male to A Male Cable: Supports Ethernet, 3D, 4K video and Audio Return Channel (ARC). It Connects Blu-ray players, Fire TV, Apple TV, PS4, PS3, XBox one, Xbox 360, computers and other HDMI-enabled devices to TVs, displays, A/V receivers and more
Cable allows you to share an Internet connection among multiple devices without the need for a separate Ethernet cable.
This cable meets the latest HDMI standards (4K Video at 60 Hz, 2160p, 48 bit/px color depth) that supports bandwidth up to 18Gbps and backwards compatible with earlier versions.
Cable Length: 6 feet (1.8 meters). It is also backed by AmazonBasics Lifetime warranty.
As some sellers on other platforms might be selling HDMI 1.4 cables as HDMI 2.0 cables. It is a no brainer to buy it from Amazon and it is covered by lifetime warranty. Thus, you are buying something that will work with your future devices.
It retails for $6.99 on Amazon. 2 pack version sells for $11.98
