We tested the AMD Ryzen 7 1800X at 3.6GHz using Cinebench R15 and confirmed that the performance of the AMD Ryzen 7 1800X is comparable if not better than expensive Intel counterparts.
The 8C/16T processor is churn out a result of 1624 cb which far surpasses that of the Intel including Intel Xeon X5650 with 12C/24T. The Core i7 6900K scored 1578 in the CPU test.
As for single thread, it scored 154cb. which is pretty fast.
Sisoft Sandra Processor Image Processing
In this test, the benchmark measures the image/photo processing (common algorithms) performance of processors.
AMD Ryzen 7 1800X final score 218 MPixel/s after individual runs of the following AVX2 tests
Blur: Convolution (3×3) Filter
Sharpen: Convolution (5×5) Filter
Motion Blur: Convolution (7×7) Filter
Edge Detection: Sobel (2*5×5) Filter
Noise Reduction: Median (5×5) Filter
The result is on par with a Core i7-5820K @ 3.3GHz scoring 201 MPixel/s and slightly faster than a Core i7 6700K clocked at 4GHz.
In terms of performance, the AMD Ryzen 7 1800X has a better price point compared to the Intel counterpart.
The AMD Ryzen 7 1800X sells for USD 499 on Amazon while
a Intel Core i7 6900k sell for USD 1022
a Intel Core I 6850K sells for USD 580
