The DJI Mic 2 is a wireless recording system that is designed for content creators, social media stars, and vloggers who want to step up the quality of their audio. The kit contains two microphones, a receiver, a sturdy charging case, and a handful of accessories for connecting to all types of vlogging gear, be that a phone, a camera, or a computer. [video]
The DJI Mic 2 is a pocket-sized pro audio device that empowers you to produce balanced and detail-rich audio content perfect for vlogs, interviews, livestreams, and more. It has a range of 250 meters (820 feet) and features intelligent noise cancelling, crystal-clear vocals, and 14-hour internal recording with 32-bit float internal recording. The device is also equipped with a 1.1-inch OLED touchscreen paired with a precision dial that provides swift access to vital information like volume and battery level while also offering precise adjustments to parameters like gain, volume, brightness, and more. [video]
The DJI Mic 2 is designed to capture authentic sounds with its premium features, including high-quality audio recording, intelligent noise cancelling, and support for 32-bit floating-point internal recording. It is sleek and compact, making it easy to carry around and use on the go. The device is available in two stylish transmitter colors: Shadow Black and Pearl White. [video]
The DJI Mic 2 has several improvements over its predecessor, the DJI Mic. The Mic 2 has a sleek metal charging case that offers additional security with a locking latch to protect against drops. The wireless recording transmitters are now available in two colors, Shadow Black and Pearl White, so you can pick one that suits your aesthetic better. [video]
Compared to the original Mic, the Mic 2 has an extended total operating time of 18 hours, which is a cool 20% increase over the original Mic’s 15-hour lifespan. The Mic 2’s capacity to support 32-bit float internal recording allows it to adapt seamlessly to complex sound environments, capturing nuances of sounds, from quiet whispers to booming decibel levels. The Mic 2 also offers direct Bluetooth connectivity, dual compatibility with Lightning and USB-C on smartphones, improved digital audio playback, and a bigger display screen with enhanced control. This means that you can pair the DJI Mic 2 with your smartphone via Bluetooth and record high-quality audio directly to your phone (not all smartphones). [video]
You can read this article on how to link up the DJI Mic 2 to the Google Pixel 8 Pro.
