Specifications
Specs
General
  • Dimensions (L×W×H)
  • 70.5×44.2×32.8 mm
  • Weight
  • 145 g
  • Waterproof
  • 16 m [1] without Waterproof Case, 60 m with Waterproof Case
  • Number of Microphones
  • 3
  • Touchscreens
  • Front Screen: 1.4-inch 326 ppi 320×320
    Rear Screen: 2.25-inch 326 ppi 360×640
    Front/Rear Screen Brightness: 750±50 cd/m²
  • Supported SD Cards
  • microSD (up to 256 GB)
  • Recommended microSD Cards
  • Recommended models:
    SanDisk Extreme 32GB V30 A2 UHS-I Speed Grade 3
    SanDisk Extreme Pro 32GB V30 A2 UHS-I Speed Grade 3
    Kingston Canvas Go!Plus 64GB UHS-I Speed Grade 3
    Kingston Canvas Go!Plus 128GB UHS-I Speed Grade 3
    Kingston Canvas React Plus 64GB UHS-II Speed Grade 3
    Kingston Canvas React Plus 128GB UHS-II Speed Grade 3
    Kingston Canvas React Plus 256GB UHS-II Speed Grade 3
    Samsung Pro Plus 256GB V30 A2 UHS-I Speed Grade 3
Camera
  • Sensor
  • 1/1.7-inch CMOS
  • Lens
  • FOV: 155°
    Aperture: f/2.8
    Focus Range: 0.3 m to ∞
  • ISO Range
  • Photo: 100-12800
    Video: 100-12800
  • Electronic Shutter Speed
  • Photo: 1/8000-30 s
    Video: 1/8000 s to the limit of frames per second
  • Max Photo Resolution
  • 4000×3000
  • Zoom
  • Digital Zoom
    Photo: 4x
    Video: 2x (> 60fps), 3x (≤ 60fps, HorizonSteady On), 4x (≤ 60fps, HorizonSteady Off)
    Slow Motion/Timelapse: Not available
  • Still Photography Modes
  • Single: 12 MP
    Countdown: Off/0.5/1/2/3/5/10 s
  • Standard Recording
  • 4K (4:3): 4096×3072@24/25/30/48/50/60fps
    4K (16:9): 3840×2160@100/120fps
    4K (16:9): 3840×2160@24/25/30/48/50/60fps
    2.7K (4:3): 2688×2016@24/25/30/48/50/60fps
    2.7K (16:9): 2688×1512@100/120fps
    2.7K (16:9): 2688×1512@24/25/30/48/50/60fps
    1080p (16:9): 1920×1080@100/120/200/240fps
    1080p (16:9): 1920×1080@24/25/30/48/50/60fps
  • Slow Motion
  • 4K: 4x (120fps)
    2.7K: 4x (120fps)
    1080p: 8x (240fps), 4x (120fps)
  • Hyperlapse
  • 4K/2.7K/1080p: Auto/×2/×5/×10/×15/×30
  • Timelapse
  • 4K/2.7K/1080p@30fps
    Intervals: 0.5/1/2/3/4/5/6/7/8/10/13/15/20/25/30/40 s
    Duration: 5/10/20/30 mins, 1/2/3/5 hours, ∞
  • Stabilization
  • EIS [2]:
    RockSteady 3.0
    HorizonBalancing
    HorizonSteady
  • Max Video Bitrate
  • 130 Mbps
  • Supported File System
  • exFAT
  • Photo Format
  • JPEG/RAW
  • Video Format
  • MP4 (H.264/HEVC)
  • Built-in Storage Capacity
  • The camera does not have built-in storage, but storage capacity can be expanded by inserting a microSD card.
  • Audio Output
  • 48 kHz; AAC
Battery
  • Type
  • LiPo 1S
  • Capacity
  • 1770 mAh
  • Energy
  • 6.8 Wh
  • Voltage
  • 3.85 V
  • Operating Temperature
  • -20° to 45° C (-4° to 113° F)
  • Charging Temperature
  • 5° to 40° C (41° to 104° F)
  • Operating Time
  • 160 mins [3]
Connection
  • Wi-Fi Operating Frequency
  • 2.400-2.4835 GHz
    5.150-5.250 GHz
    5.725-5.850 GHz
  • Wi-Fi Protocol
  • 802.11 a/b/g/n/ac
  • Wi-Fi Transmission Power (EIRP)
  • 2.4 GHz: < 16 dBm (FCC/CE/SRRC/MIC)
    5.1 GHz: < 14 dBm (FCC/CE/SRRC/MIC)
    5.8 GHz: < 14 dBm (FCC/CE/SRRC)
  • Bluetooth Operating Frequency
  • 2.400-2.4835 GHz
  • Bluetooth Transmission Power (EIRP)
  • < 4 dBm
  • Bluetooth Protocol
  • BLE 5.0
