Google just launched the new Pixel 6 and Pixel 6 Pro smartphone with it’s own Tensor processor. Although it has some impressive specs, the Pixel 6 and Pixel 6 Pro will be available in eight countries at first including Australia, Canada, France, Germany, Japan, Taiwan, UK and US.
Update from Google Singapore : Pixel 6 and Pixel 6 Pro will be available in 12 counties total, starting with the U.S, Canada, Japan, Australia, Taiwan, U.K, Germany, France, and Ireland on October 28th and then Spain, Italy, and Singapore early next year.
Here are some of the specs.
In the US, there are two different models Pixel 6 Pro models , one with Sub 6 only and the other Sub 6 and mmWave support.
Two US models
[5G Sub 6GHz]17 Model GLUOG
GSM/EDGE: Quad-band (850, 900, 1800, 1900 MHz)
UMTS/HSPA+/HSDPA: Bands 1,2,4,5,6,8,19
LTE: Bands B1/2/3/4/5/7/8/12/13/14/17/18/19/20/25/26/28/29/30/32/38/39/40/41/42/46/48/66/71
5G Sub-617: Bands n1/2/3/5/7/8/12/14/20/25/28/30/38/40/41/48/66/71/77/78
eSIM
[5G mmWave + Sub 6GHz]17 Model G8VOU
5G mmWave17: Bands n257/n258/n260/n261
eSIM
Availability and Compatibility
Unfortunately, just like Pixel 5 series, Pixel 6 and Pixel 6 Pro won’t be launched in Singapore. Taiwan and Japan will be the only Asia countries to launch the Pixel 6 series.
In Taiwan, the model will be GLUOG and it does not support mmWave.
As per Google’s tradition, they will probably not provision foreign handsets to work with the 4 local telcos since they won’t be selling it locally in Singapore. So, if you intend to parallel import them and use it here, you might end up running in 4G mode only.
[5G Sub 6GHz]17 型號:GLUOG
GSM/EDGE:四頻 (850、900、1800、1900 MHz)
UMTS/HSPA+/HSDPA:頻帶 1、2、4、5、6、8、19
LTE:頻帶 B1/2/3/4/5/7/8/12/13/14/17/18/19/20/25/26/28/29/30/32/38/39/40/41/42/46/48/66/71
5G Sub-617:頻帶n1/2/3/5/7/8/12/14/20/25/28/30/38/40/41/48/66/71/77/78
eSIM 卡
Pixel 6 Specs:
- 6.4-inch 90Hz Display
- 4525 mAh Beyond 24-Hour Battery Life
- Fast Wireless Charging
- 8GB RAM
- 128/256GB Storage
- Google Tensor Chip
- 50MP Wide Camera
- 12MP Ultrawide Camera
- 8MP Front Camera
- IP68 Water and Dust Resistance
Pixel 6 Pro Specs:
- 6.7-inch 120Hz Display
- 4900 mAh Beyond 24-Hour Battery Life
- 12GB RAM
- 128/256/512GB Storage
- 50MP Wide Camera
- 48MP Telephoto Camera
- 11MP Front Camera
The Pixel 6 starts at USD 599 (~SGD 808) and the Pixel 6 Pro starts at USD 899 (~SGD 1213).
