It is available on LAZADA at S$165 , Shopee at S$153 after $30 discount
For professionals, gamers, and content creators who demand ultra-fast network connectivity, the ORICO USB4 Single Port 10G Ethernet Adapter is a compelling solution. Designed for high-speed, low-latency networking, this adapter is compatible with Thunderbolt 3 and 4 and delivers reliable 10GBASE-T Ethernet performance. Whether you need stable connectivity for large file transfers, streaming, or low-latency gaming, this adapter ensures a seamless networking experience.
It is also suitable for those who wish to test out their 10 Gbps fibre broadband limit on their USB4 capable high end notebooks or desktop connected through this device via ONT.
Key Features
USB4 and Thunderbolt 3/4 Compatibility
One of the standout features of this ORICO adapter is its full compatibility with USB4 and Thunderbolt 3/4 interfaces. This ensures maximum performance when connected to high-end laptops, desktops, and workstations, providing the flexibility needed for professional environments.
Blazing Fast 10GBASE-T Ethernet
With support for 10 Gigabit Ethernet, this adapter offers significantly faster data transfer speeds compared to traditional Gigabit Ethernet solutions. This is particularly beneficial for applications such as:
- 4K/8K video streaming and editing
- Large file transfers and backups
- Low-latency online gaming
- Cloud computing and virtualization
RJ45 Connector with Backward Compatibility
The RJ45 port supports multiple speeds, including 10Gbps, 5Gbps, 2.5Gbps, 1Gbps, and 100Mbps, making it a versatile choice for various network infrastructures. Whether you’re using it for enterprise-level networking or home setups, the adapter seamlessly adjusts to your needs.
Plug-and-Play Convenience
ORICO ensures a hassle-free experience with plug-and-play functionality. Most modern operating systems, including Windows, macOS, and Linux, support this adapter without requiring additional driver installations, making setup straightforward.
Aluminum Alloy Build for Heat Dissipation
Networking at 10Gbps generates significant heat, but the ORICO USB4 Ethernet adapter is built with an aluminum alloy shell that aids heat dissipation. This ensures sustained high performance without thermal throttling.
Compact and Portable Design
Despite its powerful capabilities, the adapter remains lightweight and compact, making it easy to carry in your laptop bag. Professionals on the go will appreciate its portability and convenience.
Performance and Real-World Usage
In real-world scenarios, the ORICO USB4 10G Ethernet Adapter delivers impressive performance. Users can expect:
- Smoother remote work experience with improved VPN and remote desktop connections.
- Faster NAS (Network-Attached Storage) access for data-heavy applications.
- Reduced latency in online gaming, ensuring a competitive edge.
- Better performance for streaming high-resolution content, eliminating buffering and lag.
Conclusion: Is It Worth It?
For those who require high-speed, reliable Ethernet connectivity, the ORICO USB4 Single Port 10G Ethernet Adapter is an excellent investment. Its support for Thunderbolt 3/4, plug-and-play functionality, and robust build quality make it a top-tier choice for professionals and tech enthusiasts. If you need a future-proof solution for your networking needs, this adapter is definitely worth considering.
In terms of pricing, is cheaper than previous 10 Gbps adaptor using the OWC Thunderbolt3 10 G adaptor. The only concern would be the noise and heat.
Pros: ✔️ USB4 and Thunderbolt 3/4 compatibility ✔️ 10Gbps high-speed Ethernet performance ✔️ Plug-and-play support for Windows, macOS, and Linux ✔️ Sturdy aluminum build for heat dissipation ✔️ Compact and portable design
Cons: ❌ Premium pricing compared to standard USB-to-Gigabit adapters ❌ Requires a high-speed network infrastructure to fully utilize 10Gbps speeds
If you’re looking for a cutting-edge networking adapter that delivers speed, stability, and ease of use, the ORICO USB4 10G Ethernet Adapter is a fantastic choice. Upgrade your network today and experience next-level connectivity!
PRICE
