Photo gallery of the ASUS O!Play HD2
The front of the ASUS O!Play HD2 has a green and red ambient light showing the on/off status of the unit. The default is OFF with the new revision of the firmware (1.11). The front panel comes with all the extension ports support. They include CF, SD/MMC, MS/MSDUO, eSATA/USB and USB port. Perhaps ASUS should consider moving them to the side.
At the rear, we see the Coaxial cable for component video, SPDIF coaxial and digital out. RCA audio video out, HDMI port, Ethernet port, PC Link port in blue. There is a reset button on the far right of the box.
Below is another view of the ports.
