Benchmark test configuration list of ASUS ENGTX460 TOP 768MB
bluetooth 21 Jul 2010
Our test configuration of the ASUS ENGTX460 graphics card is as follow :
Mainboard : BIOSTAR 890FX
CPU : AMD Phenom II X4 960T
Memory : Kingston KHX16000D3ULT1K3/6GX DDR3-1600 @ C9-9-9-27-1Ttotal 4GB)
HDD : Hitachi Deskstar HDS728080PLA380 82.3GB
Cooler : Gigabyte G-Power II Pro
Graphics card: ASUS ENGTX460 768MB
The graphics card is first tested at it’s factory default clock speed. Subsequently the card is overclocked by increasing the GPU Core, Vcore, Shader clock, memory clock. The third test involve setting the highest AA/AF setting in Forceware driver (some applications will ignore), the fourth test runs the card with some AA/AF settings within the application to see the impact on frame rate and score.
In all the tests, CPUand ram are fixed at it’s default speed.
