Unboxing and Video Review
Contents
Unboxing and Benchmark
The Belkin BOOST↑Charge Pro Dual USB-C Wall Charger has a height of 3 cm, a length of 6.6 cm, and a width of 6.35 cm. It weighs 215 g and has a power output of 65W. The package includes the Belkin BOOST↑Charge Pro Dual USB-C Wall Charger and a Quick Install Guide.
We put the charger to the test with our Redmi Note 11 Pro 5G smartphone. This device supports both charging methods QuickCharge and Power Delivery with PPS. As the Belkin Charger supports only Power delivery, we expect it might take a longer time to charge up the phone from 0% to 100%.
In our test, it took only 28 minutes to reach 50% charge and 1 hr 4minutes to 100% charge.
During a different test, we conducted a charging test on the Samsung Tablet S7 FE 5G, which is compatible with 45W fast charging. The tablet, which has a battery capacity of 10,090 mAh, was charged from 0% to 100%. The charging process took approximately 46 minutes to reach 50% (from 1:27 pm to 2:13 pm), and it was fully charged after approximately 2 hours and 8 minutes at 3:35 pm. If you were to use the default charger, it would have taken 3 hours.
If you are looking for a reliable, efficient, and portable charging solution for your USB-C devices, look no further than the Belkin BOOST↑Charge Pro Dual USB-C Wall Charger. With its Dual USB-C Ports, fast charging capabilities, and GaN Technology, it is the ultimate charging solution for on-the-go professionals and gadget enthusiasts.
If a device requires a proprietary charging method, it can still work with this product since it supports PD/PPS. However, it may not charge at the same speed as when it is paired with its own specific charger.
You can purchase it on Shopee.sg (S$75) or Amazon.com (US model at USD 32.49)
