Intro
Contents
Oppo Reno 6 Pro is the latest addition to it’s mid high range slate. This seems to be a general trend among smartphone players to diversify it’s portoflio to include both Qualcomm and Mediatek chips.
Powered by the Mediatek Dimensity 1200, the Reno 6 Pro supports Dual SIM 5G SA/NSA while the Snapdragons are still 4G+5G for either slot. This is probably chosen as a lower cost 5G chipset as it’s performance is on par with some of the higher end snapdragon already available in the market.
The Oppo Reno6 Pro 5G is lightweight at 177g and is one fo the slimmest 5G smartphone you can find in the market at only 7.6 mm. Dimension 160 x 73.1 x 7.6mm.
It comes with a 6.5″ AMOLED screen with a refresh rate of 60/90 Hz. It is visible under the bright sun.
Comes with a big memory size of 12 GB RAM + 256 ROM, there is enough space for all your apps and photos and videos.
The main focus of this phone is it’s camera features and it’s Bokeh Flare Portrait Video which takes impressive video with a bokeh effect.
Camera
Rear
64MP Main Camera: f/1.7; FOV81°; 6P lens, support AF, adopt closed-loop focus motor
8MP Ultra Wide-angle Camera: f/2.2; fov120°; 5P lens
2MP Macro Camera: f/2.4; fov89°; 3P lens
2MP Mono Camera: f/2.4; fov89°; 3P lens
64 MP OmniVision ov64b
8 MP SONY IMX 355
2 MP GalaxyCore gc02m1b
2 MP Omnivision ov02b10
Front
32MP (f/2.4); fov81°; 5P
Image Size
Rear:
Maximum size: 6936 x 9248 (64MP)
Photo sizes in different aspect ratios:
3468 x 4624 (4:3)
3468 x 3468 (1:1)
2080 x 4624 (full screen)
2608 x 4624 (16:9)
Front:
Maximum size: 4896 x 6528 (32MP)
4896 x 6528 (4:3)
4896 x 4896 (1:1)
2944 x 6528 (full screen)
3680 x 6528 (16:9)
Video :
Rear
4K@30fps, 1080P@60fps/30fps, and 720P@60fps/30fps
Front
1080P@30fps (default) or 720P@30fps
4G and 5G Radio
As for 5G support, both SIM slot works for both 5G SA and NSA network. Supported bands include
5G SA: n1/3/5/7/8/28/41/78
5G NSA: n77/78/38/40/41/1/3/5/7/8/28 BlockA&BlockB
4G bands
FDD-LTE: Bands 1/2/3/4/5/7/8/12/17/18/19/20/26/28
TD-LTE: Bands 38/39/40/41
Connectivity
There is also support of wireless LAN stanard of up to 802.11ax. Bluetooth 5.2, audio codec of SBC, AAC, aptX, aptX HD and LDAC are supported. it also supports NFC for your mobile payments.
