Specifications
Specifications Sheet
Model Name
α7 II (ILCE-7M2)
Lens mount
E-mount
Image sensor
Image sensor
35mm full frame (35.8 x 23.9mm), Exmor CMOS sensor
Number of pixels (effective)
Approx. 24.3 megapixels
Lens mount
E mount
Recording format
Still images
JPEG (DCF Ver. 2.0, Exif Ver. 2.3, MPF baseline compliant), RAW (Sony ARW 2.3 format)
Movies
XAVC S / AVCHD format Ver. 2.0 compliant / MP4
Movie functions
Picture Profile
Picture Profile (Off/1-7, Black Level, Gamma (Movie, Still, Cine1-4, ITU709, ITU709 [800%], S-Log2), Black Gamma, Knee, Color Mode, Saturation, Color Phase, Color Depth, Detail, Copy, Reset)
Other
Time Code/User Bit, Rec Control, Auto Slow Shutter, Dual Video Rec, Marker Setting
Clean HDMI output
1920 x 1080 (60p (50p) / 60i (50i) / 24p
YCbCr 422 8bit/RGB 8bit
Media
Memory Stick PRO Duo, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo, SD memory card, SDHC memory card (UHS-I compliant), SDXC memory card (UHS-I compliant)
Focus system
Type
Fast Hybrid AF (phase-detection AF/contrast-detection AF)
Focus point
Full frame: 117 points (phase-detection AF) / APS-C: 99 points (phase-detection AF) /25 points (contrast-detection AF)
Sensitivity range
EV -1 to EV 20 (at ISO 100 equivalent with F2.0 lens attached)
Exposure control
Metering type
1200 zone-evaluative metering
ISO sensitivity (Recommended Exposure Index)
Still images: ISO 100-25600 (ISO 50/64/80 expandable), AUTO (ISO 100-6400, selectable lower limit and upper limit), Multi Frame NR (expandable up to ISO 51200)
Movies: ISO 200-25600 equivalent, AUTO (ISO 200-6400)
Shutter
Shutter speed
Still images: 1//8000 to 30 sec., Bulb
Movies: 1/8000 to 1/4 sec.
Electronic front curtain shutter
Yes (On / Off)
SteadyShot INSIDE (image stabilisation)
Image Sensor-Shift mechanism with 5-axis compensation (Compensation depends on lens specifications)
4.5 steps (Based on CIPA standard. Pitch/yaw shake only. With Sonnar T* FE 55mm F1.8 ZA lens mounted. Long exposure NR off.)
Drive
Continuous shooting speed*1
Hi: Max. approx. 5fps, Low: Max. approx. 2.5fps
No. of recordable frames (approx.) during continuous shooting*1
Continuous shooting Hi: 77 frames/25 frames (RAW)
Viewfinder
Type
Electronic viewfinder (XGA OLED Tru-Finder)
Total number of dots
2,359,296 dots
Field coverage
100%
Magnification
Approx. 0.71x (with 50mm lens at infinity, -1m-1 diopter)
LCD screen
Type
7.5cm (3.0 type) TFT drive
1,228,800 dots
Adjustable angle
Up approx. 107 degrees, down approx. 41 degrees
Audio
Microphone
Built-in stereo microphone
Speaker
Built-in, monaural
Interface
Multi interface shoe, HDMI micro connector (Type-D), Microphone terminal (3.5mm Stereo minijack), Headphone terminal (3.5mm Stereo minijack), Multi / Micro USB Terminal
Wireless LAN (built-in)
Wi-Fi Compatible, IEEE802.11b/g/n (2.4GHz band)
NFC
NFC Forum Type 3 Tag compatible
PlayMemories Camera Apps
Yes
Battery
Rechargeable battery pack NP-FW50
Weight
Approx. 599g (with battery and Memory Stick PRO Duo)
Approx. 566g (body only)
Dimensions
Approx. 126.9 x 95.7 x 59.7mm (W x H x D, CIPA compliant)
Operating temperature
0-40°C
