If you are looking for a new wireless router that can handle the blazing-fast speeds of 2.5 Gbps fibre broadband, you might want to consider getting one that supports Wi-Fi 6E. Wi-Fi 6E is the latest standard of Wi-Fi that operates on the 6 GHz band, which offers more channels, less interference, and higher throughput than the previous 2.4GHz and 5GHz bands. Wi-Fi 6E routers can also take advantage of the 2.5GbE port which allows you to enjoy up to 2.5Gbps of wired internet connection.
In this post, we will introduce some of the best Wi-Fi 6E routers that come with 2.5GbE port and Wi-Fi 6E support. These routers are:
- ASUS ROG Rapture GT-AXE16000
- MSI Radix AXE6600
- Netgear Nighthawk RAXE300
- Netgear Orbi RBRE960
- TP-Link Archer AXE300
Amazon : USD 499
This is the ultimate Wi-Fi 6E router for gamers and enthusiasts who want the best performance and features. The ASUS ROG Rapture GT-AXE16000 boasts a quad-core 1.8GHz processor, 1GB of RAM, and 256MB of flash memory. It can deliver up to 11,000Mbps of combined Wi-Fi speed, with 4,800Mbps on the 6GHz band, 4,800Mbps on the 5GHz band, and 1,148Mbps on the 2.4GHz band. It also has 6x LAN ports, including a 2.5G WAN port, a 10G LAN port, and 4x Gigabit LAN ports. It supports gaming-focused traffic shaping and packet prioritization, RGB lighting, and a boosted 6GHz amplifier for reliable Wi-Fi.
MSI Radix AXE6600
Amazon : USD 159.99
This is the latest Wi-Fi 6E router from MSI, the renowned gaming brand. The MSI Radix AXE6600 has a sleek and futuristic design, with a touch screen display and a dragon logo. It can deliver up to 6,600Mbps of combined Wi-Fi speed, with 4,800Mbps on the 6GHz band, 1,200Mbps on the 5GHz band, and 600Mbps on the 2.4GHz band. It also has 4x LAN ports, including a 2.5G WAN port and 3x Gigabit LAN ports. It supports a dedicated gaming mode that optimizes the network performance for online games, as well as a smart connect feature that automatically selects the best band for each device.
Amazon USD 299.99
This is Netgear’s “good-deal” Wi-Fi 6E router that offers fast speeds and user-friendly features. The Netgear Nighthawk RAXE300 has a simple and elegant design, with four external antennas and a LED indicator. It can deliver up to 3,000Mbps of combined Wi-Fi speed, with 1,200Mbps on the 6GHz band, 1,200Mbps on the 5GHz band, and 600Mbps on the 2.4GHz band. It also has 4x LAN ports, including a 2.5G WAN port and 3x Gigabit LAN ports. It supports a user-friendly app that lets you manage your network settings and parental controls, as well as a voice control feature that works with Amazon Alexa and Google Assistant.
Amazon USD 529.99
This is an excellent Wi-Fi 6E router that can also work as a mesh system with other Orbi satellites. The Netgear Orbi RBRE960 has a compact and stylish design, with a ring LED indicator and a hidden fan. It can deliver up to 6,000Mbps of combined Wi-Fi speed, with 4,800Mbps on the 6GHz band, 1,200Mbps on the 5GHz band, and 600Mbps on the 2.4GHz band. It also has 4x LAN ports, including a 2.5G WAN port and 3x Gigabit LAN ports. It supports a tri-band design that delivers strong coverage and performance, as well as a smart roaming feature that connects you to the best signal as you move around your home.
Amazon USD 449.99
This is TP-Link’s best Wi-Fi 6E router to date that has a compact and elegant design. The TP-Link Archer AXE300 has a minimalist and modern design, with six internal antennas and a LED indicator. It can deliver up to 3,000Mbps of combined Wi-Fi speed, with 1,200Mbps on the 6GHz band, 1,200Mbps on the 5GHz band, and 600Mbps on the 2.4GHz band. It also has 4x LAN ports, including a 2.5G WAN port and 3x Gigabit LAN ports. It supports a powerful quad-core processor that handles multiple connections with ease, as well as a home shield feature that provides advanced security and parental controls.
Synology RT6600AX
Amazon USD 299.99
The Synology RT6600ax (US) is a tri-band Wi-Fi 6E router that supports the expanded 5.9 GHz spectrum, which offers more channels and higher throughput than the previous Wi-Fi standards. It has a 2.5GbE port that can be used for WAN or LAN, and it can create up to 5 separate networks for different devices and purposes. It also has various features to enhance the security and performance of your network, such as parental controls, web filtering, traffic control, threat prevention, and VPN server. It is compatible with laptops, gaming consoles, smartphones, and other Wi-Fi devices, and it comes with a main unit, an AC power adapter, a RJ-45 LAN cable, and a quick installation guide. It is suitable for home use and has a special feature of WPS.
We hope this blog post has helped you to find the best Wi-Fi 6E router for your fibre broadband. Please feel free to leave a comment below Thank you for reading!
