PCI-E x1 Graphics Card with DX10.1 Ready!
Albatron G210-512 PCIe x1
Albatron, Taipei, 2010/02/12 – As a professional motherboard and graphics card manufacturer, Albatron Technology is keeping developing key components for IPC clients. After announcement of the first PCIe x1 VGA – GeForce 9500GT PCIE-1X -in 2009, Albatron unveils the second PCIe x1 VGA to market in 2010 Feb. Albatron G210-512 PCIe x1 is the first graphics card with both PCIe x1 interface and DX 10.1 ready!
Albatron G210-512 PCIe x1 features NVidia GeForce 210 Graphics Processor Unit (GPU) and branded DDR2 memories and supports the latest multimedia output, such as HDMI and DVI. Equipped with hi-quality capacitors & large-sized heat sink, it performs well in both efficiency and stability. Furthermore, as far as the space of computer cabinet is concerned, Albatron G210-512 PCIe x1 is adapted in low-profile design. Compared to the standard graphics cards, it’s more suitable with small form factor mother boards.
The design idea of Albatron G210-512 PCIe x1 is focused on multi-display application to maximum the space and source of monitor display. With the high bandwidth of PCI-E x1 (512MB/s), users can enjoy Blue-ray video fluently. No mater for multi-monitoring in industry control area or screen extension in flight stimulation, Albatron G210-512 PCIe x1 can complete assignments successfully. In addition, purchasing a graphics card for servers, the interface of PCI-E 1X can satisfy the discrete graphics needs and provide better image, high-definition and 3D performance.
Albatron spares no effort in global environment, and all materials of products follow the standard of RoHS, the latest rule EU announced to reduce the damage toward human and animals. User can be relieved to purchase and use Albatron’s products. For more information, please visit: www.albatron.com.tw
Specs
Graphics Processor?
GeForce 210
CUDA Cores?
16
Graphics Clock?
589 MHz
Processor Clock?
1402 MHz
Memory Clock?
500 MHz
Memory size?
512 MHz
Memory interface width?
64-bit
NVIDIA PureVideo?
Yes
NVIDIA CUDA?
Yes
NVIDIA PhysX?
yes
Microsoft DirectX?
10.1
OpenGL?
3.1
HDMI?
Yes
Audio input for HDMI?
Internal
Bus support?
PCI-e 2.0 (x1)
Max Digital resolution?
25601 x 600
Max VGA resolution?
2048 x 1536
One thought on “Alabtron releases first PCIe x1 card Albatron G210-512 with DX10.1 support”
  1. 64257 389228 It?s hard to discover knowledgeable individuals on this topic, but you sound like you know what you?re talking about! Thanks 101325
Comments are closed.
