Apple responded to the iPhone 4 reception issues in a way admitting to reception issues of the iphone 4 depending on how you hold it.
If you own an iPhone 4, the reception issue can be tested out by cover the bottom-left corner of the phone and bridge the gap between the notch there with your naked flesh, you could see some signal degradation.
Yes, you read that right: it’s not a software or production issue, simply a matter of the physical location of your hand in regards to the phone’s antenna. The company’s suggested fix? Move your hand position, or get a case which covers that part of the phone, thus breaking contact. As you can see in the email above which just arrived in our tip box, this is a sentiment which runs pretty high at the company. Here’s the official statement:
Gripping any mobile phone will result in some attenuation of its antenna performance, with certain places being worse than others depending on the placement of the antennas. This is a fact of life for every wireless phone. If you ever experience this on your iPhone 4, avoid gripping it in the lower left corner in a way that covers both sides of the black strip in the metal band, or simply use one of many available cases.
We know what you’re thinking, and we’re thinking it too: this sounds crazy. Essentially, Apple is saying that the problem is how you hold your phone, and that the solution is to change that habit.
