If you have upgraded to iOS 8, you would have noticed that there is a new feature known as iCloud Drive. In fact, iCloud Drive is Apple’s answer to Microsoft’s OneDrive. With this software, you can now store and access all your documents in one place from any of your devices.
With iCloud Drive, you can safely store all your presentations, spreadsheets, PDFs, images, and any other kind of document in iCloud. Documents you store in iCloud Drive will be kept up to date across all of your devices, and you can access them from your iPhone, iPad, iPod touch, Mac, or PC.
Here’s what you can do with iCloud Drive:
◾Store and access all of your documents in one place from any of your devices
◾Keep files and folders up to date across all your devices
◾Create new files and folders from iCloud-enabled apps
◾Work on the same file across multiple apps
What do I need to use iCloud Drive?
Make sure you have iOS 8 or OS X Yosemite on all of your devices. Here are the requirements:
◾iPhone, iPad or iPod touch with iOS 8
◾Mac with OS X Yosemite (available this fall)
◾PC with Windows 7 or later and iCloud for Windows 4.0
◾Safari 6 or later, Firefox 22 or later, or Google Chrome 28 or later
◾An active Internet connection
After you update to iOS 8 or OS X Yosemite, also update your iWork apps (Pages, Numbers, and Keynote) to the latest versions. Learn more about using iWork with iCloud Drive.
