ASUS Introduces the All-New GT 440 Graphics Card with Super Alloy Power
NVIDIA’s Fermi technology combines with exclusive ASUS innovations for smooth home theater PC entertainment and DirectX® 11 gaming
Singapore (February 7, 2011) An instant upgrade over integrated graphics, the new ASUS GT 440 graphics card is ideal for driving multimedia center PCs while enabling smooth gaming. It features ASUS exclusive technology Super Alloy Power, which delivers a 15% performance boost*, 35°C cooler operation* and 2.5 times longer lifespan*. The GT 440 further ships factory-overclocked at 822MHz, or 12MHz more than reference cards, and comes with ASUS’ Voltage Tweak for easy overvolting for up to 50%* faster clock speeds. The proprietary ASUS Dust-proof Fan contributes additional protection against heat and wear and tear, while GPU Guard strengthens the card for an extended product lifespan.
Product highlights
  • ASUS factory overclocks the GT 440 to 822MHz, which is 12MHz over reference. This delivers DirectX® 11 and Windows® 7-optimized performance, with support for the newest effects in PC graphics, including enhanced tessellation and real-time ray tracing.
  • The ASUS GT 440 includes Super Alloy Power technology, featuring a special alloy formula used in power delivery components such as capacitors, chokes and MOSFETs. It instantly lowers average operating temperatures by 35°C*, extending product lifespan 2.5 times* and improving overall performance by 15%*. This gives users access to greater overclocking potential, as the GT 440 can withstand higher-grade operation than its reference counterparts.
  • Taking advantage of the better power delivery offered by Super Alloy Power formulation, ASUS exclusive overvolting utility Voltage Tweak is capable of increasing clock speeds by up to 50%*.
  • ASUS Dust-proof Fan design ensures up to 25%* longer fan lifespan than generic offerings due to its double-sealing build, which repels dust and other debris to improve cooling and longevity. It runs quieter than the coolers on reference cards, creating a more pleasant environment for home theater enjoyment.
  • ASUS GPU Guard doubles printed circuit board strength and endurance, helping protect the card against fracturing and cracking.
Specifications
Model ENGT440/DI/1GD5
Graphics engine NVIDIA® GeForce® GT 440
Bus standard PCI Express® 2.0
Video memory 1GB GDDR5
Engine clock 822MHz
CUDA cores 96
Memory clock 3200MHz (800MHz GDDR5)
Memory interface 128-bit
DVI max resolution 2560 x 1600
D-Sub max resolution 2048 x 1536
D-Sub output D-Sub x1
DVI output DVI-I x1
HDCP compliant Yes
HDMI output HDMI x1
Software bundled ASUS utilities and driver
Dimensions 8.46” x 5.11” x 1.22”
