Whether you’re planning a relaxing getaway to Batam or a short business trip to Jakarta, staying connected is a must. Thankfully, with affordable SIM cards offering roaming data bundles, you can access the internet the moment you land in Indonesia. But with multiple options available, which one should you choose? Here’s a detailed breakdown and analysis of the best low-cost SIM plans for roaming in Indonesia.
SIMBA: Versatile Coverage and Voice Call Support
Data & Networks:
Voice & Messaging:
  • One of the biggest advantages of SIMBA is the ability to make free voice calls back to Singapore.
  • You can also make IDD calls to local Indonesian numbers.
  • Incoming SMS is supported, ensuring you don’t miss important messages.
Who Should Choose SIMBA? If you need reliable data and voice connectivity, SIMBA is the best choice. With the option to switch between two networks, you get broader coverage and higher reliability. This plan is especially beneficial for business travelers who need to stay reachable via regular calls.
SIMBA wallet top up on Shopee
Maxx: Affordable APAC Roaming with Limited Network Access
Data & Networks:
  • Maxx’s $9.90 plan includes 10 GB APAC data and 2 GB international roaming data, giving you a total of 12 GB.
  • Roaming is limited to XL Axiata, meaning you won’t have the option to switch networks if coverage is poor.
Voice & Messaging:
  • Voice calls are not supported, so you won’t be able to make or receive calls.
  • You can receive incoming SMS, which is useful for authentication messages or travel updates.
Who Should Choose Maxx? If you mainly use mobile data for apps like WhatsApp, Telegram, or Zoom and don’t require voice calls, Maxx is a budget-friendly option. However, being restricted to only one network (XL Axiata) means you might experience connectivity issues in some areas.
Maxx Top up on Shopee
Eight: Similar to Maxx, But on Indosat
Data & Networks:
  • Eight’s $8.00 plan also offers 10 GB APAC data and 2 GB international roaming data, totaling 12 GB.
  • Roaming is restricted to Indosat, providing an alternative network option compared to Maxx.
Voice & Messaging:
  • Like Maxx, voice calls are not supported.
  • You can receive incoming SMS.
Who Should Choose Eight? Eight is a good alternative to Maxx, especially if Indosat provides better coverage in your destination. If you’re looking for a budget plan with solid data roaming but don’t need calls, Eight could be your ideal pick.
Eight Top up on Shopee
Final Verdict: Which SIM is Best for You?
The best SIM for roaming in Indonesia depends on your needs:
  • Need voice calls and reliable network coverage? Choose SIMBA for its dual-network roaming and free calls to Singapore.
  • Want a budget-friendly option with ample data? Maxx (XL Axiata) and Eight (Indosat) both offer 12 GB of data but lack voice call support.
  • Prefer flexibility in network selection? SIMBA provides access to both Smartfren and Telkomsel, which may offer better coverage in different regions.
Before making a choice, consider whether you prioritize data, voice calls, or network flexibility. With the right plan, you can enjoy seamless connectivity on your trip to Indonesia!
