Motherboard layout
mainboard top
backplate
The back panel comprises of PS/2 keyboard, 6 USB ports, D-SUB, DVI-D, HDMI,  GbE and audio ports.
mainboard top left
On the top left corner of the motherboard, we can see the 3 full length PCIe 3.0 slots that supports CrossFireX.
2 x PCI-E x16 3.0 Slot (CFX x8)
1 x PCI-E x16 2.0 Slot (x4)
3 x PCI-E x1 2.0 Slot
On the edge of the board is the ALC898 audio codec with dedicated circuitry for the 7.1 CH audio.
mainboard bottom left
On the bottom left of the mainboard are 6 SATA 6Gbps ports supporting RAID 0,1,5,10. There is also a front USB 3.0 connector, debug led, Power On/off , reset switches and the front panel connectors.
mainboard bottom right
On the bottom right of the mainboard are 4 DIMM slots supporting up to DDR3-2800+ (OC).
mainboard top right
On the right hand corner of the board is the LGA1150 CPU socket with surrounding components including the VRM, DisplayPort chipset, GbE chipset etc.
BIOSTAR HI-FI Z87X 3D LGA1150
One thought on “BIOSTAR Hi-Fi Z87X 3D motherboard Review”
  1. Biostar is I guess the most underrated motherboard vendors out there. Could have all the features a famous board has but at a very affordable price.
Comments are closed.
