We have seen some leaks of the upcoming Intel Z97 chipset motherboards from other vendors. Today, we come across the pictures of the upcoming board from Biostar.
BIOSTAR Hi-Fi Z97WE motherboard features the newer chipset supporting the next generation processors.
Similar to the earlier series of motherboards, this board also supports PURO Hi-Fi sound with it’s dedicated circuitry for high definition audio. We can also see from the board it supports HDMI 4K video and has Dual GbE LAN.
There are also two full length PCIe 3.0 for SLI or CrossFireX. There are 6 SATA 6Gbps ports, USB 3.0 supported. It supports up to DDR3-2800+ for overclocking. There is also NGFF M.2 10Gb/s port for supporting SSDs.
as 2 nd tier manufacturer, it is struggling with competition from other vendors.
She may not have the looks of a prom queen but she can definitely be
effortlessly fun if given the chance and shines in other ways that you
don’t normally consider.
