You now have a choice to choose and AMD AM4 based motherboard as your mining board of choice. With the powerful AMD processors, you not only can mine with multiple GPUs, you can take advantage the multi core/thread of the Ryzen processor to mine coins like Monero which takes advantage of CPU power.
The two boards are TA320BTC and TB350-BTC
TB350-BTC Ver. 6.x
Socket : AM4
- Support AMD Ryzen CPU / APU
- AMD B350 single chip architecture
- Support 2-DIMM DDR4-3200(OC)/ 2933(OC)/ 2667/ 2400 up to 32G maximum capacity
- Support DVI-D
- Support USB 3.1 Gen1
- 1 x PCI-E 3.0 x16 Slot(x16 for Ryzen CPU only, NPU/APU run at x8 speed)
- 2 x PCI-E 3.0 x1 Slot
- 3 x PCI-E 2.0 x1 Slot
TA320-BTC Ver. 6.x
Socket : AM4
- AMD A320 single chip architecture
- Support 2-DIMM DDR4-2667/ 2400 up to 32G maximum capacity
- Support DVI-D
