You can now mine Ethereum or any alternate coins using ethOS. ethOS, a 64-bit Linux OS; giving miners the simplest way to set up a mining rig. This comes as great news for anyone who wanted to dabble with mining, but was not sure how. With the ethOS mining OS, there is no need to install drivers, configure Windows or compile software, while BIOSTAR crypto mining motherboards are tried and tested with the ethOS mining OS, making it as simple as boot and mine. Get ready to collect your Ethereum, Zcash, Monero and many other gpu-minable coins.
[amazon_link asins=’B07571T721,B0736PV196,B072JGJ8NS,B072LXX4NF,B06Y3NDXLH,B07481N9LW’ template=’ProductGrid’ store=’o041d-20′ marketplace=’US’ link_id=’ec2f5ed9-d432-11e7-83b0-99dbdeaee102′]
In the example, the setup uses 12 AMD or NVIDIA cards paired on a TB250-BTC Pro motherboard.
The system is booted up using USB preloaded with ethOS. One thing to note is that CSM support must be enabled if AMD graphics cards are used.
Type force-local on command line to turn remote config off. Select edit local config to change your wallet, main mining pool & backup mining pool address. Reboot!
Type default password “live” to reboot. Easy & quick to start mining!
