BIOSTAR has announced the J1800NH2, a mini ITX mainboard with CPU on board, (known as System on a Chip or SoC). These boards are small and efficient using a small form factor with a fan-less embedded CPU, and have low power consumption. It’s a small, quiet solution for all manner of industrial applications.
The BIOSTAR J1800NH2 is the latest in all-in-one board that takes advantage of the optimized performance of Intel’s Bay Trail chipset by delivering a new generation of technology with value-added features and easy integration.
The J1800NH2 board, being in the mini-ITX form factor, is backwards compatible with ATX and micro-ATX form factors. The ITX form factor allows you to build small and energy efficient solutions. The J1800NH2 is a simple, affordable and internet centric computer design in a compact 17x17cm size. It is the ideal solution for an ultra small form factor system and easily used with various chassis makes.
For the Smart Office situation, the J1800NH2 ITX board will give you a budget saving dual core computing based on the Intel J1800 chips. This is a silent, fan-less design featuring low power consumption. It is perfect for office space saving and creating a neat and tidy office area, and ultra speed data transfers are no problem with the USB 3.0 interface. It also features USB Poly-switch which is BIOSTAR’s on board dedicated power fuse to help prevent USB port failures by preventing USB Port over currents and safe-guarding your system and devices.
With the J1800NH2 there are a multitude of business applications such as Digital Signage, Thin Clients, Point of Sales units and Kiosks
For more on the J1800NH2 go to: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=739
