ASRock USB 3.1 Motherboards Debuting at CeBIT 2015
TAIPEI, Taiwan, March 13, 2015 – The global leading motherboard brand ASRock will be debuting the latest SuperSpeed+ USB 3.1 motherboards at CeBIT 2015 Hall 15 Booth D21. With the USB 3.1 specification announced last summer, USB 3.1 featured devices will definitely be in the spotlight at CeBIT 2015.
Besides Type-A Super Speed+ USB 3.1 which is backwards compatible with former USB 3.0/2.0/1.1 ports, ASRock motherboards are also going to be the first in the world to carry Type-C USB 3.1 ports that will support next generation mobile devices. Now, all types of USB 3.1 grants up to 10Gb/s data rates, however only this Type-C interface has a reversible design, so that connectors may fit either way. Moreover, compared to USB 3.0 which only allows 0.9 ampere charging, Type-C USB 3.1 supports up to 3.0 ampere fast device charging, and its durability has been enhanced to withstand over ten thousand plugs and removals. Selected ASRock Z97 chipset motherboards will support both USB 3.1 Type-A and Type-C ports.
ASRock will also be displaying models such as X99 OC Formula/3.1, X99 Extreme6/3.1, X99X Killer/3.1 and other X99 chipset motherboards with USB 3.1 and X Series OC Socket. These newly designed sockets unlock the hidden performance of Intel LGA 2011-3 socket CPUs, boost DDR4 memory frequencies, and offer better stability while overclocking. X99 OC Formula/3.1, X99 Extreme6/3.1 and X99X Killer/3.1 will support an onboard Type-C USB 3.1 port and bundle a USB 3.1 Card/A+A. The world’s very first X99 mini-ITX motherboard, X99E-ITX/ac will also be debuting in the ASRock CeBIT 2015 line-up, a great choice for downsizing your system while optimizing performance!
ASRock USB 3.1 motherboards
