Built for the high end desktop Ryzen Threadripper, the Zenith Extreme can be paired up with this new 16 cores and 32 threads based on the new Zen microarchitecture processor for the fastest performance on earth.
The Zenith Extreme comes with Quad DDR4 channels, and it’s backed by up to a whopping 64 PCIe 3.0 lanes for multiple graphics cards and ultra-fast NVMe SSDs.
Threadripper’s Moar Bandwidth philosophy extends to the Zenith Extreme’s networking, which is highlighted by integrated Wi-Fi based on the latest 802.11ad standard. For even faster speeds, we include a 10G Ethernet card that pushes throughput an order of magnitude higher than typical Gigabit. The 10G card also supports intermediate 2.5G and 5G standards, so you can step up to faster wired networking gradually.
Customization is one of the best things about building a PC. Thanks to RGB lighting, you can pick any colors you want along with effects that range from tastefully discreet to practically obscene. Our Aura Sync lighting synchronizes an ecosystem of components to harmonize illumination across an entire PC, both inside and out. In the Zenith Extreme, it manifests in diffused LED slashes across the I/O shield and PCH heatsink. We turn off the usual LEDs on the DIMM.2 module to preserve the concentrated illumination our designers desired. A bit of restraint goes a long way in the RGB world.
