Pricing S$399
Shopee https://s.shopee.sg/8Kc9gJtnuu
Lazada https://c.lazada.sg/t/c.YvRQdW
Mobile 4G routers are not new; they have been around for over a decade, allowing users to share mobile data with nearby devices for internet access. These routers initially existed as mobile hotspots, providing internet access but limited by 802.11n/ac/ax speed constraints. With advancements in chipsets, faster speeds are now achievable through 4G Advanced and 5G and by leveraging Wi-Fi 7, these new generation routers can distribute higher bandwidth, ensuring better connectivity for all connected devices.
So, why do we even need a mobile router ? Well, If you’re someone who’s always on the move or runs a mobile business, a 5G mobile router offers unmatched portability. It’s perfect for food trucks, pop-up shops, or frequent travelers, as it works wherever there’s 4G/5G coverage. Additionally, these routers are great for individuals who dislike long-term commitments, as they typically don’t require a 12- or 24-month contract. Setup is a breeze—just pop in a SIM card, and you’re ready to go without waiting for a technician.
The 5G mobile router isn’t just portable and convenient; it’s also powerful. With 5G and Wi-Fi 7 technology, it delivers blazing-fast internet speeds suitable for streaming, gaming, and video conferencing. On top of that, you can attach a desktop phone to the router and use the SIM card’s number to make and receive traditional calls, which is particularly useful for small businesses or home offices. Pairing the router with affordable SIM-only plans adds even more value. For instance, in Singapore, options like 100GB for $7.06/month or 300GB for $10/month make it an economical choice. In fact, there are some mvno that are offering a whopping 750 GB local data for only $8/mth.
In short, a 5G NR Wi-Fi 7 mobile router is the way to go if you need flexibility, mobility, and easy setup, while fiber broadband remains the top choice for stability and long-term cost efficiency. When the fibre broadband is down, the 5G Router can also serve as a backup. Whether you’re on the go or rooted in one spot, the right internet solution ensures you stay connected in the best possible way!
Watch our video review on packaging, detail configuration and speed test.
