The hype surrounding the DJI Osmo Pocket 4P has been absolutely wild lately. But let’s be real—does this tiny, gimbal-stabilized camera actually deserve a spot in your gear bag, or are you better off just sticking to your phone?
To find out, I put the Pocket 4P through its paces in a head-to-head showdown against two of the biggest heavyweights on the market right now: the iPhone 15 Pro Max and the Insta360 X5.
Here is what went down when we took them into the real world.
The Zoom Battle: Pocket 4P vs. iPhone 15 Pro Max
Can a dedicated pocket camera actually beat out the reigning king of smartphones? I pushed the zoom capabilities on both devices to see how they handled a distance test (12x on the Pocket vs. 15x on the iPhone).
At standard, wide focal lengths, both of these devices look incredible. But once you start cropping in, the differences become pretty obvious:
  • The iPhone’s Advantage: The iPhone 15 Pro Max still wins on pure dynamic range, thanks to its Dolby Vision support. More importantly, as you zoom in and out, the iPhone seamlessly transitions between its different physical lenses. The color grade stays perfectly consistent the entire time.
  • The Pocket 4P Flaw: The Pocket 4P features a dual-lens setup—a massive 1-inch stacked wide sensor (20mm equivalent, $f/2.0$) and a smaller 1/1.28-inch telephoto sensor (60mm equivalent, f/1.8). While the hardware is impressive, you will notice a distinct color shift in your footage the moment the camera switches between those two sensors while zooming.
A quick word of warning on low light: Our footage shows that under a dark environment, pushing that digital zoom introduces a ton of noise and some really aggressive, ugly oversharpening. If you plan on pushing the camera to its max 12x digital zoom, definitely save it for a brighter environment where the sensor has plenty of light to work with.
Staying Smooth: Pocket 4P vs. Insta360 X5
If you do any kind of action, travel, or lifestyle vlogging, stabilization is everything. I locked both cameras into 4K at 50fps and went for a walk to see how they compared.
Side by side, the color reproduction and overall clarity are shockingly close. But the second you start moving around, the Pocket 4P completely runs away with the win.
The Insta360 X5 relies entirely on Electronic Image Stabilization (EIS). It tries its best, but you can still see a constant, muddy micro-jittering throughout the footage. The Pocket 4P, on the other hand, uses a physical, 3-axis mechanical gimbal. Paired with that huge 1-inch main sensor, it gives you that buttery-smooth, cinematic look that digital stabilization just can’t replicate. It’s not even a fair fight.
The Solo Creator’s Best Friend: Frame Tag
If you shoot content by yourself, the new Frame Tag feature is going to be your absolute favorite thing about this camera. It completely takes the guesswork out of self-vlogging by automatically tracking you and keeping you dead center in the frame.
You can set the camera down on a tripod and control the framing from up to 10 meters away. Whether you’re doing a sit-down talking-head video or moving across a room for a tutorial, it acts like a personal camera operator.
Walking the Dark: Low-Light Performance
Small cameras are notorious for falling apart the second the sun goes down, but the Pocket 4P actually blew me away here.
When you’re shooting wide on the 1-inch main LOFIC sensor, it handles crazy, high-contrast night shots with a massive 17 stops of dynamic range. It navigates dimly lit environments with incredible clarity, keeping digital noise to a minimum and holding onto the fine details. Just remember the rule we mentioned earlier: don’t zoom in when it’s dark. Keep it wide, and the low-light footage looks beautiful.
The Verdict: Should You Buy It?
So, is the DJI Osmo Pocket 4P worth the cash?
If you are a content creator who needs flawless stabilization, great low-light performance, and seamless solo-shooting tools like Frame Tag, then yes—absolutely.
Sure, your iPhone is still going to be a bit smoother when zooming thanks to its seamless lens-switching and Dolby Vision. But for a dedicated, reliable, throw-in-your-pocket production tool that can handle demanding conditions, the heavy-hitting hardware inside the Pocket 4P is incredibly tough to beat.
Price Information (click below for pricing on Shoppe.sg)
Osmo Pocket 4P Standard Combo(Black): S$779
Osmo Pocket 4P Vlog Combo (Black): S$879
Pricing on Lazada.sg
https://s.lazada.sg/s.UCxUj?c=d&t=p-iF0wKNn-s2C8kCSj
If you have missed our unboxing video, you can watch it here again
