First we take a look at the BIOS System Overview of the default configuration and after UCC is turned on.
Using BIOS L1.53, the BIOS isn’t able to detect the name of the unlocked cores. It only shows as “AMD Processor model unknown (64 bit)”. The L1, L2 and L3 cache size do differ. From the original X4’s 512KB L1, 2M L2 and 6M L3, the BIOS now detects it as 768KB of L1, 3MB L2 and 6MB L3.
When the system boots up with the UCC enabled, the Count number of cores shows 6 instead of the usual 4.
3 thoughts on “Exclusive – ASRock 890GX Extreme3 Motherboard is first board to unlock Phenom II X4 and turn it into a X6”
  1. [OCWorkbench] AMD Phenom II X4 960T hidden cores can be unlocked, - Page 2 - Overclock.net - Overclocking.net says:
    […] gaise,,, The 940T doesn't exist and the 960T runs at 3ghz default. __________________ CPU-Z – YouTube SSD budget – $213/278 function showHide(what){ […]
    1. When quoting news, please use quote [OCWORKBENCH] and not ocw or ocwb or oc workbench . There is no space in between the OC and WORKBENCH
Comments are closed.
