GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of premium gaming
hardware, today announced new AMD Radeon™ RX 6600 XT graphics cards with AMD RDNA™ 2
gaming architecture. The Radeon™ RX 6600 XT GAMING OC PRO 8G, Radeon™ RX 6600 XT
GAMING OC 8G and Radeon™ RX 6600 XT EAGLE 8G graphics cards are engineered to deliver
incredible high-framerate 1080p gaming performance.
The graphics cards in the GAMING OC series feature the WINDFORCE cooling system and RGB
Fusion 2.0, making them the best choice for performance-minded gamers. The EAGLE series is the
best choice for those who desire a unique design, while maintaining both efficiency and durability.
GAMING OC – High Performance and Efficient Cooling.
The GIGABYTE WINDFORCE 3X cooling system features three unique blade fans, alternate
spinning, composite copper heat pipes in direct contact with the GPU, 3D active fans and Screen
cooling that work together to provide efficient heat dissipation. The middle fan spins in reverse to
optimize airflow for heat dissipation, enabling more efficient performance. These cooling
technologies keep the graphics card temperatures low at all times, resulting in higher and more
stable performance.
WINDFORCE fans utilize graphene nano lubricant, which can extend fan life by 2.1 times,
delivering nearly the lifespan of the double ball bearing while providing quiet operation. RGB fusion
2.0 allows users to adjust the color of the lights and various special effects, and synchronize with
other AORUS devices. The metal back plate not only strengthens the overall structure of the
graphics card, but also prevents the PCB from bending or sustaining damage. Due to its ULTRA
DURABLE certified components, advanced cooling technology and custom RGB lighting, GAMING
OC is the best choice for performance gamers.
EAGLE – Unique and Durable.
EAGLE graphics cards also feature WINDFORCE 3X cooling technology, 3D active fans, Screen
cooling, and graphene nano lubricant, enabling optimal heat dissipation and performance. The
design of EAGLE graphics cards is inspired by science-fiction with mechanical materials, a
transparent cover, and a bright logo. In addition, the back plate not only strengthens the overall
structure of the graphics card, but also prevents the PCB from bending or sustaining damage.
GIGABYTE graphics cards use a multi-phase power supply, providing over-temperature protection
and load balancing for each MOSFET and allowing the MOSFET to operate at a lower temperature.
The ULTRA DURABLE-certified chokes and capacitors provide excellent performance and longer
system life. For more information and news on GIGABYTE products, please visit the official
GIGABYTE
