Motherboard Layout
With a black PCB and bright green scheme, the PCIe and the DIMM slots stands is visually captivating. It can be clearly seen from the board the dedicated audio traces on the top left of the motherboard with the caps surrounding the Realtek audio chip. Near to the golden coloured capacitors, there are 2 dip switches which can be set to change the levels of implication to suit your speakers or earphones.
Further down, there are the 2 full length PCIe slots can operate in CrossFire mode at 4x + 16x mode. The AMD FM2+ socket sits right next to it. On the left bottom corner of the board are 8 SATA ports and they support RAID 0, RAID 1, RAID 5, RAID 10, and JBOD.
The memory slots supports DDR3 2400(OC)/2133/1866/1600/1333 MHz memory modules and AMD Memory Profile (AMP)/Extreme Memory Profile (XMP) memory modules.
