Gigabyte to showcase Slate PC S1080  at CeBIT 2011
At the CeBIT event next week, Gigabyte will be showcasing their tablet based on the Atom processor.
The S1080 Slate PC is powered by Intel Dual Core Atom N550/570 CPU. It uses a 10.1″ capactive multi touch screen. The hardware comes with a 7mm HDD, DDR3, USB 3.0, USB 2.0, D SUB and SD card slot.It will be powered by Windows 7 Home Premium.  The S1080 weighs 880g.
If you noticed, the specs seems to be a netbook. You are right as no tablets has RJ45 LAN port but it is available on the S1080.
On top of that it has WiFi, BT v3.0 and 3.5G HSDPA support.
