At CES 2026, GIGABYTE, a world-leading computer brand, introduces the AORUS GeForce RTX™ 5090 INFINITY graphics card—an engineering milestone that pairs a space-saving design with a next-generation cooling solution. Built with the revolutionary WINDFORCE HYPERBURST Cooling System and GIGABYTE’s first-ever separated PCB layout, this flagship card sets a new standard for airflow efficiency and compact performance in high-end gaming systems.
Thermal performance has always been central to GIGABYTE graphics card design, as effective cooling is essential to unlocking the full power of a GPU. Powered by NVIDIA Blackwell architecture, GeForce RTX 50 Series GPUs deliver transformative capabilities for gamers and creators alike. With immense AI horsepower, the RTX 50 Series enables new experiences and exceptional visual fidelity—boosting performance with NVIDIA DLSS 4, accelerating image generation, and empowering creativity through NVIDIA Studio.
The AORUS GeForce RTX 5090 INFINITY adopts an advanced separated PCB design pioneered by NVIDIA, paired with the WINDFORCE HYPERBURST Cooling System and a Double Flow Through design. This configuration allows airflow to pass cleanly through both sides of the backplate, ensuring smooth, unobstructed heat dissipation. An integrated Overdrive Fan at the core of the card engages under heavy workloads, delivering an extra surge of cooling to maximize gaming performance and fully unleash RTX AI computing power.
Visually, the card stands out with a striking circular design highlighted by a bold die-cast metal plate, a custom circular heatsink, and GIGABYTE’s signature RGB Halo lighting. Blending premium craftsmanship with a breakthrough thermal solution and a distinctive aesthetic, the AORUS GeForce RTX 5090 INFINITY maintains a compact footprint—measuring just 33 cm in length and 14.5 cm in height—ensuring broad compatibility across a wide range of PC chassis without compromising performance.
