One of the most exciting updates to Magic Editor is the new Reimage feature. This tool goes beyond simply erasing, moving or camouflaging objects; it allows you to seamlessly add AI-generated images to your selected areas. For instance, you can enhance a night sky with fireworks just by typing “add fireworks.”
With Magic Editor ReImagine, you can effortlessly use AI to create entirely new and imaginative visuals that you might not have thought of before.
ReImagine
Zoom Enhance
Zoom Enhance lets you zoom into and crop your photos while AI fills in missing details. This makes your images look sharper and more detailed, even if you zoom in a lot.
Instead of just enlarging pixels, Zoom Enhance uses smart AI to understand and recreate the missing details. This means your zoomed-in or cropped photo still looks clear and natural.
You can then save it and get a more detail look at your zoom in photo.
Auto Frame
Auto Frame is a cool feature in Google’s Magic Editor that uses AI to make cropping and framing your photos easier and better.
Auto Frame uses AI to understand your photo, recognizing key elements like the subject and background. It then provides crop suggestions based on what makes the photo look its best. It also cuts down on manual cropping and adjustments, speeding up your editing.
Combining all these AI tools available on the Pixel 9 Pro XL, you can recreate the ‘perfect’ photo.
