The Honor 600 Pro is Honor’s latest smartphone that succeeds the Honor 400 Pro, the phone that is remembered to be one of the first that can effortlessly transform a still image into a 5-second video clip.
The Honor 600 Pro takes things further by enhancing it’s processor and features. Powered by the Snapdragon 8 Elite, it delivers flagship performance with AI processing capabilities alongside the raw performance needed for everyday use and gaming.
At first glance, the design resembles the iPhone 17 Pro Max, especially in the orange color variant, though the camera module sets it apart. Weighing just 200g and measuring 7.8mm thin, it features ultra-narrow bezels and a matte metal frame which is nice to hold. The only probably complain would be the smaller screen size of 6.57″.
The small compact device is IP68, IP69, and IP69K water and dust resistance for added durability. While most expensive phone only provides a 5000 mAh battery, Honor 600 Pro gives you a massive 7000 mAh battery, supporting 80W wired SuperCharge, 50W wireless SuperCharge, and 27W wired reverse charging. The battery should last you at least 1.5 days without needing a recharge.
The the Honor 600 Pro impresses with a 200MP main sensor featuring a large 1/1.4-inch sensor and OIS + EIS stabilization. With CIPA 6.5-level stabilisation, handheld night photography becomes an easy task as it helps to stabilise my shaky hands. Even in video shoot, the stablisation also seem to help in giving me cinematic shoots in 4K HDR.
Other than the main sensor there is 12MP ultra-wide camera, a 50MP portrait selfie camera, and a 50MP periscope telephoto lens with 3.5x optical zoom and OIS. With AI Super Zoom 2.0, you can enhance images taken from 10x up to 120x using cloud-based algorithms for improved clarity. Videos can be shot up to 10x digital zoom.
Building on its predecessor’s success, the Honor 600 Pro introduces Image-to-Video 2.0, pushing AI-generated video creation to a whole new level. You can now provide up to three images as keyframes to generate dynamic video content using prompts. Alternatively, choose from over 14 templates for cinematic camera movements and effects.
Unboxing video
Getting started is simple, just press the AI button to quickly create content from start to finish. You can also generate videos directly from the image gallery app.
With Moving Photo Eraser, you can remove unwanted people or objects from a moving photo. So, you can now remove it from the moving photo just like you did with static photo.
There’s also the AI Photo Agent, you can use voice commands to add or move objects within photos using voice.
