Taipei, Taiwan – Apr. 24, 2019 – HyperX, the gaming division of Kingston Technology, today announced the release of two new high speed Predator DDR4 memory kits in 4266MHz and 4600MHz frequency versions. The new frequency options will be available as 8GB modules in kits of two and include a black aluminum heat spreader and black PCB to complement the look of the latest PC builds by system builders and DIY PC enthusiasts.
HyperX Predator DDR4 delivers fast frequencies and low latencies with speeds up to 4600MHz with latencies from CL12-CL19. The Extreme Memory Profile (XMP) allows users to overclock memory beyond standard industry specifications. HyperX memory modules pass a rigorous XMP certification test procedure to be certified. Intel XMP ready and certified profiles are optimized for Intel’s latest chipsets and are compatible with many of AMD’s latest chipsets.
“We’re excited to offer Predator DDR4 for the next generation of PC enthusiasts who want the best performance from their systems,” said HyperX.” As HyperX continues to support the world of gaming and esports, the community sees us as a trusted leader for high speed memory in the gaming hardware industry.”
The dependable Predator DDR4 offers extreme performance and reliability and is 100 percent factory tested for speed and backed by a lifetime warranty.
Availability
HyperX Predator DDR4 speed additions will be available through HyperX’s network of retail and e-tail outlets. For more information, please visit https://www.hyperxgaming.com/.
HyperX Predator DDR4 Speed Addition Specifications:
Capacities
• Kits of 2: 16GB
• Frequencies: 4266MHz, 4600MHz
• Latencies: CL19
• Voltage: 1.4V, 1.5V
• Operating Temperatures 0°C to 85°C
• Dimensions: 133.35mm x 42.2mm x 8.3mm
Part Number | Description |
HX442C19PB3K2/16 | 16GB 4266MHz DDR4 CL19 DIMM (Kit of 2) XMP HyperX Predator |
HX446C19PB3K2/16 | 16GB 4600MHz DDR4 CL19 DIMM (Kit of 2) XMP HyperX Predator |
