Today , Microsoft launches 5 new Surface products. The two that caught many people by surprise are the Surface Neo and Surface Duo. Microsoft is back in the mobile space but this time round, the devices are powered by Android.
Surface Neo
Surface Neo is dual-screen device built for productivity on Windows 10X, an expression of Windows 10. A 360-degree full-friction hinge connects two 9” screens, enabling Surface Neo to adapt to whatever posture you need in the moment. When you open it you have a full-size 13” display in the thinnest LCD in its class. It’s built for productivity and multitasking like a true PC would be – running full productivity apps, with a removable keyboard and compatibility with Surface Pen and Bluetooth® mouse.
Surface Duo
Surface Duo is the first Surface to fit in your pocket. Surface Duo brings together the best of Microsoft productivity experiences, Android apps and Surface hardware design into a single device you can take anywhere. And, yes, it makes phone calls. It has two paper-thin 5.6-inch screens that unfold to 8.3 inches, and just like Surface Neo, it can be used in a variety of modes to let you work the way you’d like.
To support Surface Neo, we are introducing Windows 10X, an expression of Windows 10 designed for a new category of dual-screen PCs. With Surface Duo we are building upon Android to marry cutting edge hardware with familiar software and services. We’re excited to work with developers and the industry to create the next wave of dual-screen computing and unlock a new era of mobile creativity.
