Kingston Ships Its Fastest, World’s Largest-Capacity USB 3.0 Flash Drive DataTraveler HyperX Predator 3.0 will be Available Up to 1TB Data Transfer Speeds up to 240MB/s Read, 160MB/s Write Certified SuperSpeed USB 3.0
Hsinchu, Taiwan – January 9, 2013Kingston, the independent world leader in memory products, today announced the DataTraveler HyperX Predator 3.0 USB Flash drive. DataTraveler HyperX Predator 3.0 is the world’s largest-capacity USB 3.0 Flash drive as it will be available in a 1TB capacity later in Q1. It is shipping now in 512GB capacity. DT HyperX Predator 3.0 is the fastest USB 3.0 Flash drive in the Kingston family, with speeds of up to 240MB/s read and 160MB/s write. It has also achieved SuperSpeed USB 3.0 certification.
“Our new DataTraveler HyperX Predator 3.0 allows users to store their entire digital world on a portable USB 3.0 Flash drive,” said Nathan Su, Flash Memory Sales Director, APAC Region, Kingston. “The large capacity and fast USB 3.0 transfer speeds allow users to save time as they can access, edit and transfer applications or files such as HD movies directly from the drive without any performance lag.”
DataTraveler HyperX Predator 3.0 is compliant with next-generation USB 3.0 specifications and is optimized for newer PCs with USB 3.0 ports. Users who work with large video or graphics files, or gamers who like to travel with their entire library will appreciate the drive’s speed and capacity. The casing is made of zinc alloy metal for superior quality, shock resistance and high-end design. DataTraveler HyperX Predator 3.0 ships with a custom Kingston key ring and a HyperX valet keychain. It is also backwards compatible with USB 2.0 for efficient data transfer rates.
DataTraveler HyperX Predator 3.0 USB Flash drive is part of the HyperX Predator family, which represents the highest-performance products offered from Kingston HyperX. The drive is backed by a five-year warranty, free technical support and legendary Kingston reliability.
Kingston HyperX Predator 3.0 Features and Specifications:
  • Highest Capacities: Uncompromised data storage to carry your digital world on a portable USB drive
  • Highest Performance: Unparalleled speeds to save time while transferring content rich data
  • Zinc Alloy Metal Casing: Resilient protection for data in a cutting-edge design
  • HyperX Valet Keychain: Exclusive accessory for a stylish twist to portable storage
  • Guaranteed: Five-year warranty and free technical support for added peace of mind
  • Speed¹: USB 3.0: 240MB/s read and 160MB/s write     USB 2.0: 30MB/s read and 30MB/s write
  • Backwards Compatible: With USB 2.0
  • Capacities²: 512GB, 1TB (later Q1)
  • Dimensions: Without key ring: 2.8346″ x 1.0606″ x 0.8268″ (72mm x 26.94mm x 21mm) with key ring: 3.4854″ x 1.0606″ x 0.8268″ (88.53mm x 26.94mm x 21mm)
  • Operating Temperature: 32°F to 140°F (0°C to 60°C)
  • Storage Temperature: -4°F to 185°F (-20°C to 85°C)
  • USB 3.03: Latest USB standard guarantees backwards compatibility with USB 2.0
Kingston DataTraveler HyperX Predator 3.0
Part Number
Capacity and Features
DTHXP30/512GB
DataTraveler HyperX Predator USB 512GB
DTHXP30/1T
DataTraveler HyperX Predator USB 1TB
