nokia lumia 1020
Nokia introduces the first 41 megapixel camera phone with it’s Lumia 1020. It boasts more detail than the eye can see to catch up with rivals Samsung and Apple.
Featuring dual capture, the Lumia 1020 can take high resolution 38 megapixel image and 5 megapixel picture for sharing on social networks.
On top of that, it also has a “floating lens” technology that adjusts to shakes and six lenses to help produce sharper images.
Powered with Windows 8, it is probably still limited to the library of apps available on the app store compared to Android and iPhone.
The new Lumia, which use Windows software, will be sold in the US from July 26 on mobile telco AT&T for $US299.99 with a two-year contract, and will be available later in other markets including China, Nokia said.
Below is a video from Associated Press.
Specifications
Tech Specs
Networks: GSM: 850 MHz, 900 MHz, 1800 MHz, 1900 MHz, WCDMA: 2100 MHz, 1900 MHz, 850 MHz, 900 MHz, LTE network bands: 1, 3, 7, 20, 8
Display: 4.5” AMOLED WXGA (1280×768), 2.5 D sculpted Corning Gorilla 3 Glass, ClearBlack, high brightness mode, sunlight readability, super sensitive touch
Battery: 2000 mAh battery, wireless charging supported via cover
Processor: 1.5GHz dual-core Snapdragon
Main camera: PureView 41-megapixel with optical image stabilization, Resolution: 7712 x 5360. Includes Nokia Pro Camera. Xenon flash for still images, LED flash for video
Front facing camera: HD 1.2-megapixel wide angle
Memory: 2GB RAM, 32GB internal memory; 7GB free SkyDrive cloud storage
I/O USB2.0, BT 3.0, NFC with SIM based security, WLAN a/b/g/n, A-GPS and Glonass, 3.5 mm audio connector
Size/weight 130.4 x 71.4 x 10.4mm, Weight: 158g
