Unboxing Video Review and Specifications
Contents
Video Review / Unboxing
Specifications
Size and Weight
Height
about 163.7 mm
Width
about 73.9 mm
Thickness
about 8.5 mm
Weight
about 218 g
*Note: Phone weight may vary slightly depending on the product configurations, manufacturing process, and measurement method.
Storage
RAM and ROM Capacities
12 GB + 256 GB
RAM Type
LPDDR5 @ 3200 MHz 4 x 16-bit
ROM Specifications
UFS3.1 @ 1×2 Lanes HS-Gear4
Phone Storage Card
Not Supported
USB OTG
Supported
* The available internal storage may be smaller as part of the internal storage is occupied by software. Actual memory space may change due to application updates, user operations, and other related factors.
Display
Size
6.70″
Screen Ratio
92.70%
Resolution
QHD+(3216 × 1440)
Refresh Rate
Maximum: 120 Hz (Dynamic)
Touch Sampling Rate
Maximum: 240 Hz (2 fingers)
Colour Gamut
Vivid mode: 97% NTSC/100% DCI-P3 (Typical)
Gentle mode: 71% NTSC/100% sRGB (Typical)
Color Depth
1.07 billion colors (10-bit)
Pixel Density
525 PPI
Brightness
Default peak brightness (typical) measured when the full screen is illuminated: 500 nits
Peak brightness (typical) measured with increasing excitation intensity: 800 nits
Peak brightness (typical) measured when only part of the screen is illuminated: 1300 nits
Brightness level: 8192
Panel
AMOLED (Flexible/LTPO)
Cover Glasses
Corning® Gorilla® Glass Victus™
Camera
Rear
50MP Main Camera: f/1.7; FOV 80°; 1G6P lens; AF supported; closed-loop focus motor; dual-OIS 5-axis stabilization
50MP Ultra-wide Angle Camera: f/2.2; FOV 110°; 7P lens; AF supported; closed-loop focus motor; 4 cm marco photography supported
13MP Telephoto Camera: f/2.4; FOV 45°; 5P lens; AF supported
Front
32MP Front Camera: f/2.4; FOV 90°; lens: 5P, fixed focus
Shooting Mode
Rear: Photo, Video, Night, Pro, Panorama, Portrait, Time-lapse, Slow-motion, Text scanner, Hi-Res, Movie, Long exposure, Dual-view video, Sticker, and Google Lens
Front: Photo, Video, Panoramic, Portrait, Night, Time-lapse, Dual-view video, and Sticker
Video
Rear
Rear camera: 4K (30fps/60fps), 1080P (30fps/60fps), and 720P (30fps/60fps)
Video Slo-mo: 1080P (240fps) and 720P (480fps)
Video zoom: 4K(30fps/60fps), 720P(30fps/60fps), 1080P(30fps/60fps)
Front
Supports 1080P/720P (30fps) (default: 1080P (30fps))
Chips
NPU
MariSilicon X Imaging NPU
CPU
Qualcomm® Snapdragon™ 8 Gen 1 Mobile Platform
CPU Speed Cores
8 cores
GPU
Adreno™ 730 @818MHz
Battery
2 × 2440 mAh/18.88 Wh (min)
2 × 2500 mAh/19.35 Wh (typ)
* Note: Two series-connected cells, equivalent to a total capacity of 5000 mAh
Fast Charge
80W SUPERVOOCTM, SUPERVOOCTM 2.0, SUPERVOOCTM, VOOC 3.0, PD(9V/2A), QC(9V/2A), 50W AIRVOOCTM, 10W Reverse Wireless Charging
*The maximum power in the low-voltage areas is 66W
Biometrics
Fingerprint
In-screen fingerprint sensor
Facial Recognition
Supported
Sensors
Geomagnetic sensor, Proximity sensor, Ambient light sensor, Color temperature sensor, Accelerometer, Gravity sensor, Multi-Spectral sensor, Gyroscope, and Pedometer
Cellular Network
SIM 2
Supported
SIM Card Type
Nano-SIM Card
Frequency Band
2G: GSM 850/900/1800/1900MHz
3G: UMTS(WCDMA) bands 1/2/4/5/6/8/19
4G: TD-LTE bands 34/38/39/40/41/42
4G: LTE FDD bands 1/2/3/4/5/7/8/12/13/17/18
/19/20/25/26/28/32/66(70MHz)
5G SA: n1/n2/n3/n5/n7/n8/n12/n13/n18/n20/n25
/n26/n28/n38/n40/n41/n66(70MHz)/n77/n78
/n79
5G NSA: n1/n3/n5/n7/n8/n20/n28/n38/n40/n41
/n66(70MHz)/n77/n78/n79
* eSIM support depends on carriers
Regions that do not support dual SIM cards: Australia (Telstra and Optus)
* Functions available on the live network depend on the situations of carrier’s network and related services deployment.
Connectivity
WLAN
Wi-Fi 6 (802.11ax), Wi-Fi 5 (802.11ac), 802.11a/b/g/n/, Wi-Fi 2.4G/5.1G/5.6G/5.8G
Supports Wi-Fi Display, Wi-Fi tethering, and Simultaneous Dual Band (Wi-Fi 2.4 GHz 2×2 + Wi-Fi 5 GHz 2×2); supports Wi-Fi 5 GHz 160 MHz
Supports 2×2 MIMO and 8 spatial-stream sounding MU-MIMO
Bluetooth Version
Bluetooth 5.2, Bluetooth Low Energy
Bluetooth Audio Codec
SBC, AAC, APTX HD, LDAC, APTX, LHDC
*LHDC is compatible with the OPPO Enco X Series and OnePlus Buds Pro Series earphones.
USB Interface
Type-C
Earphone Jack
Type-C
NFC
Supports reading from and writing to 13.56 MHz NFC cards
Supports NFC-SIM card (Only supported for SIM 1) and HCE (such as Google Pay)
Operating System
ColorOS 12.1 based on Android 12
Location Technology
GNSS
Built-in GPS, A-GPS, BeiDou, GLONASS, Galileo, and QZSS positioning systems supported
Frequency Antenna
GPS: L1
Galileo: E1
BeiDou: B1I + B1C
QZSS: L1
Others
AGPS, Wi‑Fi, Cellular, Digital compass
Maps
Google Maps and other third-party map apps are supported
In the Box
Phone x 1
Charger x 1
USB Data Cable x 1
SIM Ejector Tool x 1
Safety Guide x 1
Quick Start Guide x 1
Protective Case x 1
Exclusive Service Card x 1
