Contents
After weeks of using the Oppo Find X5 Pro, I find that the phone is very responsive. This is not just in terms of screen refresh and launching of applications, the camera is amazinly fast to focus and snap even at low light environments. The dedicated imaging NPU, MariSilicon X is definitely helps a lot.
Although there is no 120W quick charging, the phone comes with a 5000 mAh battery can be charged up to 50 percent in 12 minutes using it’s enhanced 80W SUPERVOOC Flash-charging technology. As for wireless charging, the 50W AIRVOOC, it powers up to 100 per cent wirelessly in just 47 minutes. So, there is less waiting time to get your phone ready.
Design wise, the Oppo Find X5 Pro slim and curved body makes it stand out as It illumintes in sunlight or shadow. It is also IP68 Water and dust resistance. No more worries using your phone the beach or poolside.
The two 50 MP IMX 766 sensor camera take excellent pictures. Unfortunately the 13 MP telephoto only provides a 5X hybrid optical zoom and 20X digital zoom. The auto sensing to auto switch to macro mode is good it can’t be bypased.
The phone comes with Air Gestures which you could wave your hand to andswer calls. the Super recorder is pretty impressive as it is able to filter off background noise. It makes it easy for recording presentations. There is also a multi screen connect which allows you to edit word or excel documents saved on the phone from your computer.
Price : S$1599 (qoo10.sg)
Pros :
- 5G SA/NSA
- 80W turbo charge
- 2 x 50 MP camera
- WIFI 6
- IP 68
Cons:
- Optical zoom limited
- 5G firmware buggy
- Performance 10
- Design 10
- Features 10
- Usability 10
- Value for money 8
- Score : 9.6 / 10
