Palit Microsystems Ltd, the leading graphics card manufacturer, announced an upgraded JetStream series at the GeForce GTX 770 Series. The Palit JetStream 風series of graphics cards features innovative cooling and an optimized product design to deliver gamers the ultimate gaming experience. As the latest and most powerful GPU in the series, the Palit GeForce GTX 770 JetStream guarantees gamers cutting-edge performance and an explosive new gaming experience.
The Powerful Just Got Better 10% Overclocking Performance
When it comes to overclocked performance, the Palit GeForce GTX 770 JetStream 2GB is integrated with DrMOS, which is a suite of optimized multi-chip power stage modules designed to offer high current circuitry, low noise levels and low heat emission. And the optimized design that ensures stable voltage supply, it’s no wonder the Palit GeForce GTX 770 JetStream 2GB is capable of transforming your PC into a visual powerhouse! The factory overclocked Palit GeForce GTX 770 JetStream 2GB provides 10% more MHz at core clock and that makes gaming performance 10% higher at enthusiast gaming setting.
Extreme Cooling Meets Whisper Quiet 15°C Cooler, 9dB Quieter
Continue the glory of Palit GTX 600 JetStream series, the new generation Palit GeForce GTX 770 JetStream 2GB comes equipped with 80-90-80 mm triple fans that are strategically placed to draw heat away from the PCB. All triple TurboFan Blade fans are designed to generate a powerful air stream and air pressure. Though the JetStream series offers a powerful cooling system, it by no means generates a large amount of noise. In fact, the Palit GeForce GTX 770 JetStream 2GB is 15°C cooler and 9dB quieter when compared to reference cards.
The upgrade features at Palit GTX770 JetStream 2GB:
l Copper Based
n Efficiently dissipate the heat from GPU and make 20% cooler
l 8 Phase PWM
n Stabilize the voltage level the improve overclocking ability.
l MasterMode
n GPU Overvoltage and Memory Overvoltage to increase extra 5+ % performance.
