Palit Microsystems Ltd, the leading graphics card manufacturer, releases the Palit GeForce GTX 780 Ti JetStream, the fastest single-GPU on the planet. The Palit JetStream 風series of graphics cards features innovative cooling and an optimized product design to deliver gamers the ultimate gaming experience. As the latest and most powerful GPU in the series, the Palit GeForce GTX 780 Ti JetStream guarantees gamers cutting-edge performance and an explosive new gaming experience. This Palit GTX 780 Ti JetStream becomes the new king of single GPU graphics cards.
Palit GeForce GTX 780 Ti JetStream has its GK110 core clocked at 980MHz, making it much faster than the stock 876MHz of NVIDIA’s reference design. Keeping things frosty under the hood are three jet engine-inspired fans (two 80mm and one 90mm) that deliver optimized air flow to the heatsink. Further improving the card’s cooling performance is the new heatsink design which consists of a copper base and five copper heatpipes for efficient heat dissipation. It also makes use of DrMOS and an 8-phase PWM design to increase the card’s stability and improve its overclocking ability. Palit GTX 780 Ti JetStream also equipped with two 8-pin PCI Express power connectors to ensures the power fully supported from the system power supply unit under heavy loading operation.
