BIOSTAR Hi-Fi Z87X 3D
The new Biostar HiFi Z87X 3D extends the Puro HiFi audio to the Z87 series of motherboards. As you are probably aware, Biostar is the first manufacturer to incorporate high quality audio components on board using a seperate circuitry, generating clear audio with lesser  noise compared to older technologies. The board supports Sound Blaster Cinema.
The Z87 chipset which supports the Intel Haswell processor uses a Socket LGA1150 design and it incompatible to existing 1155 processors.
This motherboard comes with 3 full length PCIe 3.0 slots and supports the Ati CrossFire and SLI. There is GbE LAN, native USB 3.0 and HDMI 4K support. The backplane comes with 2 USB 3.0, 4 USB 2.0 D-SUB, DVI-D PS/2 keyboard, GbE and audio ports.
On board you can also find the SATA 6Gbps ports, 4 DIMM slots supporting up to DDR3-2800+ (OC).
The board should go on sale in early June to coincide with Intel’s launch at Computex Taipei 2013.
Hi-Fi Z87X 3D and box Hi-Fi Z87X 3D v0.59_45 angle Hi-Fi Z87X 3D v0.59_IO Hi-Fi Z87X 3D v0.59_s Hi-Fi Z87X 3D v0.59_top
