Xiaomi officially make available the Redmi Note 15 Pro 5G globally in mid Jan 2026, positioning it as a major part of the company’s 2026 smartphone lineup. Marketed as a “mid-range flagship,” the device places strong emphasis on display quality, battery endurance, camera capabilities, durability, and long-term software support.
Display and Performance
The Redmi Note 15 Pro 5G sports a large 6.83-inch 1.5K AMOLED display with a 120Hz refresh rate and a claimed 3,200 nits peak brightness, ensuring excellent outdoor visibility and smooth scrolling.
Powering the device is the MediaTek Dimensity 7400 Ultra, built on a 4nm process, delivering a balance between performance efficiency and sustained workloads.
Design and Build
In terms of design, the Redmi Note 15 Pro 5G manages to stand out in a crowded mid-range market. The device features a distinctive purplish marble blue backplate, which gives it a more premium and visually striking appearance compared to standard flat-color finishes. The marble-like pattern adds depth and character, helping the phone maintain a unique identity without appearing overly flashy.
This design is paired with Xiaomi’s “Titan” reinforced structure and Gorilla Glass Victus 2, rated to withstand drops of up to 2.5 meters, striking a balance between aesthetics and durability.
Camera Capabilities
On the imaging front, the phone features a 200MP primary camera with OIS and an f/1.7 aperture+1/1.4 inch sensor. It also comes with an 8MP ultrawide sensor of f/2.2. Xiaomi enables up to 30× digital zoom for still photos, while video recording supports up to 6× digital zoom.
A 20MP f/2.2 front-facing camera handles selfies and video calls.
Battery and Charging
The Redmi Note 15 Pro 5G packs a 6,580mAh battery. Charging is handled via 45W wired fast charging and 22.5W reverse charging.
Software, Connectivity, and Ecosystem Features
Out of the box, the device runs HyperOS 2 (based on Android 15), bringing smoother UI animations, improved system efficiency, and deeper ecosystem integration.
Connectivity is comprehensive, with support for 5G SA and NSA networks, ensuring compatibility with both standalone and non-standalone 5G deployments. The phone also supports Wi-Fi 6, delivering faster speeds, lower latency, and improved performance in congested environments.
Additional features include Xiaomi Offline Communication, which allows users to call nearby Xiaomi smartphones via Bluetooth without any cellular or network connection, as well as eSIM support, replacing the second physical SIM slot (SIM2).
Xiaomi has confirmed 4 major Android version upgrades and 6 years of security patches, placing the Redmi Note 15 Pro 5G among the better-supported smartphones in its class.
Durability and Protection
Beyond everyday water resistance, the device carries an It is IP66/IP68/IP69/IP69K dust and water resistance rating, providing protection against dust, water immersion, and even high-pressure, high-temperature water jets—a level of durability rarely seen outside rugged smartphones.
Key Specifications at a Glance
- Display: 6.83-inch 1.5K AMOLED, 120Hz, up to 3,200 nits
- Processor: MediaTek Dimensity 7400 Ultra (4nm)
- Rear Cameras: 200MP (OIS) + 8MP ultrawide
- Zoom: Up to 30× digital (photo), up to 6× digital (video)
- Front Camera: 20MP
- Battery: 6,580mAh (up to 7,000mAh in select markets)
- Charging: 45W wired fast charging
- OS: HyperOS 2 (Android 15)
- Connectivity: 5G SA/NSA, Wi-Fi 6, eSIM (replaces SIM2), Xiaomi Offline Communication (Bluetooth calling)
- Durability: Gorilla Glass Victus 2, IP68/IP69K
