Intro
Contents
As wireless technology continues to advance, the MSI HERALD-BE NCM865 Wi-Fi 7 Wireless Adapter stands out with its impressive set of features designed to enhance your network experience. From blazing speeds to advanced modulation schemes, this adapter promises to push the boundaries of wireless performance. Here’s a comprehensive review of the NCM865, including insights from our testing and its compatibility with various systems.
Unleash Blazing Fast 5.8 Gbps Transfer Speeds
The MSI HERALD-BE NCM865 is engineered to deliver exceptional data transfer speeds of up to 5.8 Gbps. This leap in speed makes it an ideal choice for activities that demand high bandwidth, such as streaming ultra-high-definition content, competitive gaming, and transferring large files. The adapter’s high-speed capabilities ensure minimal latency and an overall enhanced performance.
Experience Broad 320 MHz Channel Widths (on 6GHz)
A notable feature of the NCM865 is its support for 320 MHz channel widths on the 6 GHz band. This expanded channel width allows for greater bandwidth, enabling more data to be transmitted simultaneously. This reduction in network congestion results in improved stability and efficiency, particularly in environments with high wireless traffic.
Improve the Modulation Scheme from 1024-QAM to 4096-QAM
The HERALD-BE NCM865 enhances data transmission with an upgrade from 1024-QAM to 4096-QAM. This advancement allows for a higher density of data encoding within each signal, boosting both speed and signal quality. As a result, users experience a more efficient and high-performing network, with smoother and more reliable connectivity.
Supports Bluetooth 5.4
In addition to its Wi-Fi capabilities, the NCM865 includes support for Bluetooth 5.4. This latest Bluetooth standard provides improved range, speed, and connectivity for various wireless devices. Whether you’re connecting peripherals like wireless headphones or keyboards, Bluetooth 5.4 ensures a stable and efficient connection that complements the adapter’s high-speed Wi-Fi performance.
Compatibility with AMD and Intel Based Motherboards
The Qualcomm NCM865 is designed to be versatile and compatible with a range of systems. It works seamlessly with both AMD and Intel-based motherboards, ensuring broad compatibility across various platforms. Whether you’re building a new PC or upgrading an existing system, the NCM865 integrates easily, making it a flexible choice for a wide array of users.
An Upgrade Worth It if Paired with a Wi-Fi 7 Router and 2.5 or 10 Gbps Fiber Broadband
To fully harness the capabilities of the MSI HERALD-BE NCM865, pairing it with a Wi-Fi 7 router and connecting to a high-speed 2.5 or 10 Gbps fiber broadband network is highly recommended. This combination maximizes the adapter’s performance, delivering unparalleled speeds and network capacity. For users with access to such advanced infrastructure, the NCM865 is a valuable upgrade that future-proofs your connectivity setup.
