Introduction
Belkin BOOST↑Charge Pro Dual USB-C Wall Charger: The Ultimate Charging Solution for Your Devices
In today’s fast-paced world, keeping our devices charged is crucial. Whether you are on the go or between meetings, having a reliable and efficient charging solution can make all the difference. Enter the Belkin BOOST↑Charge Pro Dual USB-C Wall Charger, a compact and portable device that can fast charge your USB-C devices, including a MacBook and an iPhone simultaneously.
Dual USB-C Ports: Double the Charging Power
One of the most significant advantages of the Belkin BOOST↑Charge Pro Dual USB-C Wall Charger is its Dual USB-C Ports. With two USB-C ports, you can charge two devices at once, including a MacBook up to 45W and an iPhone up to 20W. This feature is especially useful if you need to power up your laptop and your phone at the same time or share the charger with a colleague or family member.
Fast Charge for iOS: Say Goodbye to Slow Charging
If you own an iPhone 8 or later, you’ll appreciate the fast charging capabilities of the Belkin BOOST↑Charge Pro Dual USB-C Wall Charger. You can charge your iPhone from 0–50% in just 30 minutes, which is up to three times faster than a standard 5W charger. This means you can spend less time tethered to a power outlet and more time enjoying your device.
GaN Technology: High-Performance and Efficient Charging
The Belkin BOOST↑Charge Pro Dual USB-C Wall Charger also features GaN Technology. This technology uses Gallium nitride, which is a high-performance and efficient alternative to the traditional silicon used in charging devices. GaN technology produces less heat and allows for more power in a compact design. This means you get faster charging times, a smaller device, and less energy waste.
Compatibility: Works with a Wide Range of Devices
The Belkin BOOST↑Charge Pro Dual USB-C Wall Charger is compatible with various iPhone, iPad, and Mac models. It works with the latest iPhone models, including the iPhone 13 Pro and the iPhone 13 mini, as well as older models like the iPhone 8 and the iPhone SE (1st generation). It also works with the latest iPad models, such as the iPad Pro 12.9-inch (5th generation) and the iPad (9th generation). Additionally, it is compatible with MacBook models such as the MacBook Air (M1, 2020) and the MacBook Air (Retina, 13‑inch, 2020).
[nextpage title=”Unboxing and Video Review”]
Unboxing and Benchmark
The Belkin BOOST↑Charge Pro Dual USB-C Wall Charger has a height of 3 cm, a length of 6.6 cm, and a width of 6.35 cm. It weighs 215 g and has a power output of 65W. The package includes the Belkin BOOST↑Charge Pro Dual USB-C Wall Charger and a Quick Install Guide.
We put the charger to the test with our Redmi Note 11 Pro 5G smartphone. This device supports both charging methods QuickCharge and Power Delivery with PPS. As the Belkin Charger supports only Power delivery, we expect it might take a longer time to charge up the phone from 0% to 100%.
In our test, it took only 28 minutes to reach 50% charge and 1 hr 4minutes to 100% charge.
During a different test, we conducted a charging test on the Samsung Tablet S7 FE 5G, which is compatible with 45W fast charging. The tablet, which has a battery capacity of 10,090 mAh, was charged from 0% to 100%. The charging process took approximately 46 minutes to reach 50% (from 1:27 pm to 2:13 pm), and it was fully charged after approximately 2 hours and 8 minutes at 3:35 pm. If you were to use the default charger, it would have taken 3 hours.
If you are looking for a reliable, efficient, and portable charging solution for your USB-C devices, look no further than the Belkin BOOST↑Charge Pro Dual USB-C Wall Charger. With its Dual USB-C Ports, fast charging capabilities, and GaN Technology, it is the ultimate charging solution for on-the-go professionals and gadget enthusiasts.
If a device requires a proprietary charging method, it can still work with this product since it supports PD/PPS. However, it may not charge at the same speed as when it is paired with its own specific charger.
You can purchase it on Shopee.sg (S$75) or Amazon.com (US model at USD 32.49)
