Benchmark test - direct vs usb-c adapter
Contents
Benchmark test
Price – $79 at Lazada
We connected the SIMBA 2.5 Gbps fibre broadband cable direct to the Belkin Connect USB-C to 2.5 Gb Ethernet Adapter and plug it into the USB-C 3.0 port on the Gigabyte AMD X570 Extreme motherboard. The results are tested against the same cable plugged directly onto the 2.5 GbE port on the same motherboard.
The results are as follow using speedtest.net app. You might be wondering why we tested it against a Malaysian server instead of a Singapore server. The reason is because Singapore server seems to be capping the bandwidth of speedtest originating from simba users. Most of the Singapore servers will throtlte the speed to max at around 1 Gbps giving you a skewed result. It would be best SIMBA host their own speedtest.net server.
Direct to the 2.5 Gbps port on the motherboard
Direct through the Belkin Connect USB-C to 2.5 Gb Ethernet Adapter plugged into USB-C port on motherboard
Using nPerf, another application which test network speed, we did compare the difference between direct 2.5 GbE port connection versus via USB-C adapter.
We chose nPerf because it provided a less congested 10 Gbps public server for us to test against.
For both Speedtest and Nperf, we can see a consistent difference of around 200 Mbps between direct connection vs usb-c adapter.
