For gamers, the ALC1220-VB audio IC would bring out the best audio quality during gaming or music listening.LGA1151 supports both Gen 8 and Gen 9 processors4 DIMM slots supporting up to 64 GB of DDR4Chipset Z390 and connectors on the left6 SATA 6 Gbps portsIn terms of cooling, the motherboard incorporates a 12+1 Phases Digital VRM solution with DrMOS. It also uses screwed on mounted MOSFET heatsink to keep things cool. The DUal PCIe Gen 3 x 4 M.2 comes with thermal guards.
What kind of voltages were you running when you had the 9700k at 5.1? I’m also quite curious as to what temps the vrm had during testing.
