Camera modes
Contents
Camera modes
Price : S$398 (Qoo10), S$378 (Lazada)
Other than the standard Photo mode (with AI), there are other options like Portrait, Video, AR Lens mode and Others.
Under Others mode, you can select Pro (Professional mode), SLow motion, Night, LIght painting etc.
In professional mode, you can adjust ISO from AUTO to 3200, Shuttle can range from 1/4000s to 30 secs. EV from -4 to +4, AF-C, AF-S or MF and white balance. With all these settings, you can create wonders by doing manual adjustments to ISO, Shuttle speed etc.
Add more fun to your pictures by AR lens. With it, you can try out 3D Qmoji (which basically follow your expressions), You can add effects, background to your pictures or videos. With 3D Objects you can add objects (see below) an object onto your picture you intend to take.
Here are some day and night shots we took using AUTO mode with AI turned on.
When taking photos, we noticed that whenever AI is turned on, you cannot use the Digital Zoom feature. It is either you Zoom without AI enable or you don’t zoom.
More photos are posted in our FB group
